Split surfaces in CFX-POST
Like Tree2Likes
  • 1 Post By Francesco
  • 1 Post By Robin
Old   July 18, 2006, 10:36
Default Split surfaces in CFX-POST
Francesco
Hello everyone,
is there a way, in CFX-POST to split a surface into two parts, for example above and below the intersection with a user-defined plane? Or, alternatively, calculate functions like areaAve only on part of a surface? Something like areaAve(Pressure)@Surface1 but only up to Z=20...
Thanks Francesco
ns.cskn likes this.
Old   July 18, 2006, 12:10
Default Re: Split surfaces in CFX-POST
Robin
Yes. Create a contour plot on the surface and specify an appropriate range or list of values and number of contours to get the divisions you want, then create a User Surface using the "from Contour" method. Basically, you can create a user surface for every contour level. These user surfaces can then be used as locators for other plots, expressions, etc.
Regards, Robin
ziggo likes this.
Old   July 18, 2006, 14:25
Francesco
Thank you SO much Robin! You can't imagine how much time this saves me... I thought it was not possible and was already thinking of terribly complicated ways to do it, for example exporting the surface coordinates to matlab and all sorts of complicated procedures.
Francesco
Importing or Creating 2D Flat Surfaces into CFX Sam CFX 5 March 30, 2013 11:11
chart for transiente simulation - CFX Post rogbrito CFX 0 June 22, 2009 12:12
CFX Post processing aditya CFX 1 July 6, 2008 12:09
ANSYS CFX POST State file Mechstud CFX 1 June 22, 2007 14:59
CFX post to Tecplot nandu CFX 2 December 4, 2002 08:27
