Calculation of the coefficients of forces and moment |
July 7, 2020, 14:02 |
Outside US and Canada
Rep Power: 5 |
Hello, I am replicating a simulation of a fluent turbine in CFX. My idea is to check the drag, moment and lift coefficients. I know that the ones I got in Fluent are close to what I want to do but when I make the same simulation using the sliding mesh method in CFX, I get completely different data. The simulation is running fine but I don't know what may be affecting the data so dramatically. I wanted to see in the Post processing that it also allows calculating the expression in a certain Time Step and comparing the values with what the CFX monitors show are different, something that seems strange to me if the two are calculating according to the solution made by CFX . Any recommendation?
PS: I am using exactly the same turbulence model and solution method. It also exports the mesh that I used in fluent, as in its 2D modeling, the program added a thickness and added the condition of symmetry between faces. CFX.zip |
July 7, 2020, 15:25 |
Rep Power: 32 |
Are you using a non-zero Reference Pressure (CFX), or Operating Pressure (Fluent) in the model?
If you read the output file in CFX, it states the reported forces/moments to do not include the contribution of the Reference Pressure.
July 7, 2020, 17:46 |
Rep Power: 5 |
Thanks for answering. I let you know that I have been learning simulation for a few months. Yes, I am using a CFX reference pressure other than 0. Exactly 1 atm. In that case where I failed and how could I solve it, Thank you very much for your help.
REFERENCE STATE: Option = Specified Point Reference Pressure = 1 [atm] Reference Specific Enthalpy = 0. [J/kg] Reference Specific Entropy = 0. [J/kg/K] Reference Temperature = 25 [C I am trying to use reference pressure on the material at 0 Atm but I don't see a favorable change. I have no idea what a mistake I am making. Last edited by ThomasYepes; July 8, 2020 at 00:09. |
July 8, 2020, 11:44 |
Rep Power: 32 |
Is that the source of your differences with Fluent? If so, just set the Domain/Reference Pressure value to 0, and adjust your boundary condition accordingly. Nothing else.
The value of the Reference Pressure should not change the final result of the solution of the flow field in any way of form. It is a numerical detail to improve round off errors. If you run in double precision, it is not needed. Unfortunately, the Reference Pressure value is not included in the post-processing quantities and it may cause confusion.
July 8, 2020, 12:29 |
Rep Power: 5 |
Hi, I just checked that the reference pressure is not the source of the results I am getting in CFX. As you say it does not noticeably affect the final results. For now I have no idea what the source of the difference I get is.
Moment calculation (Hydrofoil) | YKNIPP | FLUENT | 15 | November 4, 2023 09:42 |
The CoP Does not exist: Validating Aerodynamic forces through a "line of action" | ds4719 | Main CFD Forum | 14 | February 18, 2022 18:05 |
Problem with forces and moment calculated for wind turbine blade using simpleFoam | mostafa kamal | OpenFOAM Running, Solving & CFD | 2 | September 21, 2021 17:33 |
getting wrong forces and force coefficients in openfoam | maddy11 | OpenFOAM | 2 | January 23, 2019 01:09 |
Center of pressure (confirmation/question) | scipy | FLUENT | 2 | March 5, 2012 06:54 |
