August 12, 2020, 04:14 |
y plus value at porous domain
William
Rep Power: 5 |
Hello.
I am trying to simulate heat exchanger including porous domain. The turbulence model is SST. In fluid domain parts, I set the y plus value between 2 and 30, but it doesn't converge well. So I have a question, is it essential to set y plus value under 30 in porous domain? I use wall boundary condition as free slip wall, so I didn't consider it's y plus value. Anybody has an idea, please notify me. Thank you in advance. |
August 12, 2020, 06:38 |
Rep Power: 143 |
Mesh resolution and convergence are totally different things. A fine mesh does not mean your simulation will converge - in fact, quite the opposite - a fine mesh is harder to converge than a coarse one.
It sounds like this FAQ is relevant to you: https://www.cfd-online.com/Wiki/Ansy...gence_criteria
August 13, 2020, 08:29 |
#3 | |
Henrique Stel
Rep Power: 17 |
August 15, 2020, 01:24 |
William
Rep Power: 5 |
Thank you for the advice.
I have a question. As you said, I tried out the mesh modify to set yplus value under 1, it's residuals became higher than before : about 1e-1, with huge oscillating. How can I reduce the residuals when the small yplus applied? I thought the courant number is the problem so I reduced the timescale factor, it doesn't very effective. And one more, how can I determine the residual criteria for convergence? I have found a post about convergence criteria (https://www.engineering.com/DesignSoftware/DesignSoftwareArticles/ArticleID/9296/3-Criteria-for-Assessing-CFD-Convergence.aspx), but it is general situation, I want to know how I can determine 'my' simulation converged. |
August 15, 2020, 03:08 |
Rep Power: 143 |
Did you read the FAQ I linked to? It answers your exact question. I don't care to type it out again.
To determine the convergence criteria you should be using you should do a sensitivity analysis. Try a range of convergence criteria and look at the effect on a simulation output of interest to you. Choose the convergence criteria which gives the accuracy you require.
August 15, 2020, 20:21 |
William
Rep Power: 5 |
I'm sorry that I cannot understand that link perfectly, I'm going to read it again.
And according to your advice, I'm going to do mesh sensitivity analysis, checking the important parameter increasing mesh number. Thank you! |
August 16, 2020, 05:34 |
Rep Power: 143 |
If you don't understand the FAQ then feel free to post a question asking for clarification. If you don't understand something then lots of other people probably don't understand it either. Make sure you explain what you don't understand, of course.
August 16, 2020, 09:24 |
#8 | |
Henrique Stel
Rep Power: 17 |
In any case, your residuals are so high right now (1e-1 as you say) that I think that it is a result of multiple problems. Revise your setup, mesh and numerical aspects very carefully. |
August 31, 2020, 07:39 |
#9 | |
William
Rep Power: 5 |
Or can you link me that I can refer to the meaning of discretization or upwind scheme? |
September 1, 2020, 12:50 |
#10 |
Henrique Stel
Rep Power: 17 |
What I was suggesting you was to run the same problem but using the Upwind scheme instead. It is a very "smooth" discretization scheme so most of the time it is numerically stable, but also inaccurate for most problems. Thus, I don't recommend you to move on with it, but just to get a solution with it and see if it shows better convergence (a pure exercise to find where the problem is).
Sorry, I don't know an internet link where you can find some 101 about discretization, but a regular Google search should help you with the basics. You could also try any CFD book. |
Out File does not show Imbalance in % | Mmaragann | CFX | 5 | January 20, 2017 10:20 |
Radiation at interface between fluid and porous domain | Hitch8 | CFX | 19 | April 20, 2015 06:24 |
Floating point exception: Zero divide | liladhar | CFX | 11 | December 16, 2013 04:07 |
Implementation of a porous domain | megacrout | OpenFOAM | 1 | January 12, 2012 07:02 |
Porous domain set-up from single pressure loss value | siw | CFX | 1 | December 8, 2011 16:36 |
