August 19, 2020, 09:34 |
CFX 2020 R2 black screen issue
Stuart
Rep Power: 25 |
Recently installed ANSYS 2020 R2 products on a Windows Server 2019 Standard machine, which I access using Remote Desktop Connection. CFX has black borders in the GUI (see image), which has never happened before. ANSYS SpaceClaim, Meshanical, Workbench and DesignModeler are all OK. This ANSYS install was the first since R19.2 as we bypassed ANSYS 2019.
Checked the ANSYS Customer Portal and Knowledge Resources: Solutions #2061743 says to add the Environment Variable QT_OPENGL=desktop. I did this but the problem still happens. Maybe I should try again but does it have to be a User Variable (I'm the only CFX User) or System Variable (co-workers do not use CFX) and must the computer be restarted for it to take effect? My IT Dept. says that the drivers are all up to date. Contacted my ANSYS Channel Partner tech support but they could not resolve the problem. Does anyone else have this issue and know how to fix it? Thanks |
August 19, 2020, 10:25 |
M
Rep Power: 12 |
Have you tried this? Helped for me a few times now with display errors. Good luck.
Stereo Mode Error |
August 19, 2020, 13:11 |
Erik
Rep Power: 23 |
Mine is black until I adjust the window size. (The part that has the black borders)
August 20, 2020, 02:01 |
Stuart
Rep Power: 25 |
@AtoHM. After I selected Stereo Mode and restarted CFX-Pre it said Stereo Mode was not available so I switched back to Normal Mode.
The hyperlink to the other post and the comment about the CFXPreferences.ccl file. There is no Stereo option in that file for me. But deleting the CFXPreferences.ccl file and then opening CFX-Pre fixed the problem once. But then CFX remakes the new CFXPreferences.ccl file then the black borders reappear. Then I have to delete the CFXPreferences.ccl file again. So the existence of the CFXPreferences.ccl is the problem. The CFXPreferences.ccl file is shown in the image. Are the WindowX or Viewer Height etc. values wrong? |
August 20, 2020, 02:40 |
M
Rep Power: 12 |
Excuse the confusion, I didn't want to suggest to switch stereo/mono, just the thread topic and how he solved it by deleting the file. But you tried that aswell, so here we go.
The WindowX-Entry seems to be belonging to the launcher, not Pre. I guess there is no "wrong" with these dimensions, they just have to fit your screen. No idea why they would be false in the first place especially when cfx generates the file from scratch, but have you tried playing with these values? Maybe you can adjust them so it fits your screen. |
August 20, 2020, 02:43 |
Stuart
Rep Power: 25 |
@AtoHM, thanks for the reply.
It seems that it can be corrected by dragging the partition between the Outline and View windows in the GUI. Is that what you were saying @evcelica? If so thanks for that. |
August 20, 2020, 10:15 |
Erik
Rep Power: 23 |
Yes, That is what I was saying. I knew it was difficult to explain correctly.
Simple fix once you know what to do. |
June 30, 2021, 03:59 |
Stuart
Rep Power: 25 |
I'm getting a full black screen in View 1 in CFX 2021 R1. This time moving the partition does not fix the problem. Is anyone else having this issue? Thanks.
June 30, 2021, 13:47 |
#9 | |
Kira
Rep Power: 8 |
Go to https://developer.nvidia.com/nvidia-opengl-rdp (you need to register). Then the exe to install is: nvidiaopenglrdp.exe Hope this helps. |
June 30, 2021, 17:36 |
#10 |
Gert-Jan
Rep Power: 27 |
There is a older query regarding black screens over RDP. Not sure, but maybe this can help as well.
Remote Desktop - Black screen |
July 1, 2021, 02:13 |
#11 |
Stuart
Rep Power: 25 |
Thanks, I set that Environment Variable and it made the screen partially black (not fully black, so that's progress!) and then dragged the partition to resolve the issue - just like I had to do above in the thread for a previous CFX version.
My company a few months ago bought a new server for our ANSYS work so the graphics drivers are all up-to-date. This, like many other issues in ANSYS, I guess will not be resolved. |
November 25, 2021, 19:28 |
Black display screen
#12 |
RA
When i open my cfx pre the app opens successfully but the workspace is all black. I cannot figure out a way on what to do. Can someone help with this.
@atohm |
Differences between CFX and OpenFOAM regarding convergence and robustness! | magjohan | OpenFOAM Running, Solving & CFD | 4 | February 26, 2015 10:26 |
VAWT simulation verification issue (CFX) | steve20024 | Main CFD Forum | 0 | February 10, 2015 08:15 |
another issue about HPC cluster for running cfx, hepl PLZ. | happy | CFX | 4 | March 4, 2012 23:58 |
Pros and Cons for CFX, CFdesign, COMSOL | Val | Main CFD Forum | 3 | June 10, 2011 02:20 |
CFX 4.4 installation problem | Pandu Sattvika | CFX | 1 | December 1, 2001 04:07 |
