Gambit to CFX
Old   August 26, 2006, 03:27
Default Gambit to CFX
Omer
I used Gambit to generate a .msh mesh. I read it in FLUENT and exported it to a CGNS file. When I read it in CFX-pre, I am not getting all of my regions. I have no boundaries. I have just one Fluid region. Therefore I am not able to specify any boundary conditions. Can anyone help?
Old   August 27, 2006, 03:47
Default Re: Gambit to CFX
zxaar
Write the mesh as .msh, read it in tgrid, export as patran neutral file and then read, it in cfx, you will have all boundary regions.
Old   August 27, 2006, 03:57
Omer
thanx a heap,Zxaar. I am going to try that right away.
Old   August 27, 2006, 04:04
Omer
Is there a way possible to do this without Tgrid? I don't have Tgrid, and after going around talking to some people i know, i realised that no one else has it either.
Thanking in anticipation
Old   August 27, 2006, 05:11
zxaar
Well I only worked with CFX one day, (last friday, So all my CFX experience is just one day), so I am still thinking of a way of doing it without tgrid. But if you do not have tgrid, download it from fluentusers.com and install it, it shall work with the same license.
Old   August 28, 2006, 05:14
Omer
Thanks a lot Zxaar for your co-operation. I finally was able to do it without Tgrid. I can read the .msh from Gambit to FLUENT. Then I need to initialise it. Then save it a PATRAN neutral file. Directly readable with all regions in CFX. Talk about coincidence, I am new to FLUENT as you are to CFX
Old   August 28, 2006, 05:39
zxaar
Yepp Patran neutral is the format requred for it. I did not explore the Fluent solver to export to partan, the simple reason was we have one month demo license and I had to do lot of calculations. So first day I was supposed to learn CFX and start the calculations. (SO I did)
Old   August 28, 2006, 10:22
deLuther
Why not use ICEM for it? If someone have CFX then, in most cases, ICEM CFD is also purchased...
Old   August 30, 2006, 11:04
Omer
Thanks you guys, zxaar and deLuther.
Old   September 23, 2006, 20:05
NH
Hi Omer, Zxaar,
Do you know whether you could create an axisymmetric model for cfx using gambit?
NH
Gambit help: Cube inside cube Jack Martinez FLUENT 13 August 11, 2010 06:29
gambit mesh to cfx Hossam CFX 1 November 9, 2008 11:39
Importing Gambit files into CFX CF CFX 8 September 25, 2006 02:14
CFX 10's solutions differ from CFX 5.7's Atit Koonsrisuk CFX 4 July 26, 2006 11:59
import gambit .neu directly to CFX? jemteo CFX 2 June 6, 2006 15:00
