Calculating The Torque From The Angle Of Shaft or Propeller’s Normal Axis
Old   October 28, 2020, 10:39
Default Calculating The Torque From The Angle Of Shaft or Propeller’s Normal Axis
butterflymuzzy is on a distinguished road
Hello Glenn and the other members,
I Want to calculate the relative rotative efficiency of a ship’s propeller. Relative rotative efficiency equals to (open water Torque/ship shaft axis Torque) of a propeller.
It is easy to calculate the Open water torque or thrust(force) from x,y and z axises. Like torque_x()@propeller or force_x()@propeller.
What I did is, when I calculate the wake of the propeller with ships hull and appendages, I easily insertEd the new axis and rotated my propeller around the inserted new axis (3 degrees shaft axis).
But the problem is how can I monitor or calculate the torque of a propeller from the new axis (ship’s shaft 3 degrees angular normal axis). It might be a expression or I can look from results with a method ?
Best.
butterflymuzzy is offline   Reply With Quote
Old   October 28, 2020, 15:41
Opaque will become famous soon enough
If you can create a local coordinate frame oriented as you want, you should be able to
torque_x_MyInclinedCoord()@Boundary
In fact, you check the correct syntax using the CFD-Post calculator, and toggle the "write the expression".
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
Opaque is offline   Reply With Quote
High torque coefficient Cm for Vertical Axis Wind Turbine (VAWT) tony00 FLUENT 11 July 23, 2018 06:13
calculating Normal vector in level set method amir2920 Main CFD Forum 1 July 21, 2009 07:25
Calculating torque Andrew FLUENT 5 September 4, 2007 11:10
turbine torque calculating in Fluent Bagus Putra Muljadi FLUENT 0 May 18, 2006 02:34
How to update polyPatchbs localPoints liu OpenFOAM Running, Solving & CFD 6 December 30, 2005 17:27
