November 23, 2020, 08:10 |
Tank, Mixing
Rep Power: 6 |
Hey guys, I have a tank within 2 liquid fluids with different densities. Inside the tank I put on forced convection (inlet-flow: 50:50 of the 2 fluids), so that they get mixed. After converged solution the density is complete homogeneous (but there should be at least a little deviation at different locations?!).
That made me a little worried, so I'm thinking, that I used the wrong model. To be sure I stoped the forced convection, with the expactation, that the two fluids will get divided again because of the different densities. They didn't. What kind of setup would you use? I read the whole documentation about multipahse flow but i'm still not sure which model would be the best. My first idea was to setup a singlefluid flow for the forced convection with a mixture of the two fluids.I did an initialization to fill the tank with 50:50 of the fluids. My Second idea was to setup multiphase flow with 2 continuous fluids with a fluid buoyancy model (density difference) and, according to the documentation, the mixture model. But the mixture model seems to be "hard to handle". I don't know what value to use for interfacial length scale and why is a drag coefficient required? Hopefully you can help me out, thanks in advance. |
November 23, 2020, 09:30 |
Gert-Jan
Rep Power: 27 |
You should first know it the liquids are miscible (e.g. water and glycerine) or inmiscible (e.g. water and oil)
November 23, 2020, 16:45 |
Rep Power: 143 |
..... and also the physics you expect to be important. Do you get one phase separating out from another? If so, how? Any chemistry? Are they mixed at the molecular level, or droplets, bubbles, free surface? What fluid movements take place?
November 24, 2020, 03:40 |
Rep Power: 6 |
Thanks for the replies.
@Gert-Jan: The liquids are two different motor fuels. I'm not a chemist but i would say that these fluids are partly miscible. For the sake of simplicity i would like to produce both kind of results (miscible and inmiscible). I don't know how to setup partly miscible for this fluids in cfx. @ghorrocks: "Do you get one phase separating out from another?" If i turn off forced convection then yes, because of the differeces of the densities. Other chemistry issues are not of interest for me. The mixing at molecular level like kinematic diffusion or diffusion because of turbulence are negligible because the mixing is strongly forced convection driven, no droplets or bubbles. By free surface you mean the interaction at the interface between two fluids? I would neglect that too, because of the strongly forced convection? (not sure). Forced convection takes place in sort of tangential flow in a cylindrical tank. Thanks again |
November 24, 2020, 05:51 |
Rep Power: 143 |
By "partly miscible" do you mean that they do mix, but the rate of mixing is slow, meaning that diffusion is slow in the mixture? If this is the case then it sounds like a multicomponent mixture is what you want, not a multiphase model. Multicomponent mixtures can handle fluids of different properties which interact through diffusion. But note its ability to separate light and heavy fluids by buoyancy is limited - I think you will find if the mass fractions of different parts of the fluid are different then CFX can model the buoyancy effect this causes, but if the mass fractions are intimately mixed then CFX will not separate them out by buoyancy.
November 24, 2020, 07:40 |
Rep Power: 6 |
Thanks, yeah exactly. thats what I tried to say. sorry for my bad formulation. I did the multicomponent simulation already. maybe you can take a look at my .ccl
MATERIAL: HeavyOil Material Group = Constant Property Liquids Option = Pure Substance Thermodynamic State = Liquid PROPERTIES: Option = General Material EQUATION OF STATE: Density = 1000 [kg m^-3] Molar Mass = 18 [kg kmol^-1] Option = Value END SPECIFIC HEAT CAPACITY: Option = Value Specific Heat Capacity = 140 [J kg^-1 K^-1] Specific Heat Type = Constant Pressure END REFERENCE STATE: Option = Specified Point Reference Pressure = 1 [atm] Reference Specific Enthalpy = 0 [J/kg] Reference Specific Entropy = 0 [J/kg/K] Reference Temperature = 25 [C] END DYNAMIC VISCOSITY: Dynamic Viscosity = 0.04 [Pa s] Option = Value END THERMAL CONDUCTIVITY: Option = Value Thermal Conductivity = 7.96 [W m^-1 K^-1] END ABSORPTION COEFFICIENT: Absorption Coefficient = 1.0 [m^-1] Option = Value END SCATTERING COEFFICIENT: Option = Value Scattering Coefficient = 0.0 [m^-1] END REFRACTIVE INDEX: Option = Value Refractive Index = 1.0 [m m^-1] END THERMAL EXPANSIVITY: Option = Value Thermal Expansivity = 1.82E-04 [K^-1] END END END MATERIAL: LightOil Material Group = Constant Property Liquids Option = Pure Substance Thermodynamic State = Liquid PROPERTIES: Option = General Material EQUATION OF STATE: Density = 700 [kg m^-3] Molar Mass = 18.02 [kg kmol^-1] Option = Value END SPECIFIC HEAT CAPACITY: Option = Value Specific Heat Capacity = 140 [J kg^-1 K^-1] Specific Heat Type = Constant Pressure END REFERENCE STATE: Option = Specified Point Reference Pressure = 1 [atm] Reference Specific Enthalpy = 0.0 [J/kg] Reference Specific Entropy = 0.0 [J/kg/K] Reference Temperature = 25 [C] END DYNAMIC VISCOSITY: Dynamic Viscosity = 0.04 [Pa s] Option = Value END THERMAL CONDUCTIVITY: Option = Value Thermal Conductivity = 0.6069 [W m^-1 K^-1] END ABSORPTION COEFFICIENT: Absorption Coefficient = 1.0 [m^-1] Option = Value END SCATTERING COEFFICIENT: Option = Value Scattering Coefficient = 0.0 [m^-1] END REFRACTIVE INDEX: Option = Value Refractive Index = 1.0 [m m^-1] END THERMAL EXPANSIVITY: Option = Value Thermal Expansivity = 2.57E-04 [K^-1] END END END MATERIAL: Mixture Material Group = User Materials List = HeavyOil,LightOil Option = Variable Composition Mixture END ANALYSIS TYPE: Option = Steady State EXTERNAL SOLVER COUPLING: Option = None END END DOMAIN: Fluid Coord Frame = Coord 0 Domain Type = Fluid Location = FLUID BOUNDARY: Out Boundary Type = OUTLET Location = AUSTRITT BOUNDARY CONDITIONS: FLOW REGIME: Option = Subsonic END MASS AND MOMENTUM: Mass Flow Rate = 46.18 [kg s^-1] Mass Flow Rate Area = As Specified Option = Mass Flow Rate END END END BOUNDARY: In Boundary Type = OPENING Location = In_1,In_2 BOUNDARY CONDITIONS: COMPONENT: HeavyOil Mass Fraction = 0.5 Option = Mass Fraction END FLOW DIRECTION: Option = Normal to Boundary Condition END FLOW REGIME: Option = Subsonic END MASS AND MOMENTUM: Option = Opening Pressure and Direction Relative Pressure = 8 [bar] END TURBULENCE: Option = Medium Intensity and Eddy Viscosity Ratio END END END DOMAIN MODELS: BUOYANCY MODEL: Buoyancy Reference Density = 0 [kg m^-3] Gravity X Component = 0 [m s^-2] Gravity Y Component = 0 [m s^-2] Gravity Z Component = -9.81 [m s^-2] Option = Buoyant BUOYANCY REFERENCE LOCATION: Option = Automatic END END DOMAIN MOTION: Option = Stationary END MESH DEFORMATION: Option = None END REFERENCE PRESSURE: Reference Pressure = 0 [atm] END END FLUID DEFINITION: Mix Material = Mixture Option = Material Library MORPHOLOGY: Option = Continuous Fluid END END FLUID MODELS: COMBUSTION MODEL: Option = None END COMPONENT: HeavyOil Kinematic Diffusivity = 1e-6 [m^2 s^-1] Option = Transport Equation TURBULENT FLUX CLOSURE: Option = Eddy Diffusivity Turbulent Schmidt Number = 0.9 END END COMPONENT: LightOil Option = Constraint END HEAT TRANSFER MODEL: Fluid Temperature = 20 [C] Option = Isothermal END THERMAL RADIATION MODEL: Option = None END TURBULENCE MODEL: Option = SST BUOYANCY TURBULENCE: Option = None END END TURBULENT WALL FUNCTIONS: Option = Automatic END END END Also it would be great if you could explain your last sentence a little bit more. What does limited mean? In my case, the mass fraction of the fluids are 50% each. because of the forced convection they get intimately mixed i guess. does it mean that the mixing process is calculated right but cfx can't separate them out by buoyancy. |
November 24, 2020, 15:23 |
Gert-Jan
Rep Power: 27 |
Not matter what.... I would not use this:
Buoyancy Reference Density = 0 [kg m^-3] I would set it equal to 700 kg/m3 |
November 24, 2020, 16:52 |
Rep Power: 143 |
My comment about buoyancy is that CFX will correctly model buoyant effect where different control volumes have different densities. So density variations which CFX resolves with the mesh will have buoyant effect correctly applied. But fluids which are intimately mixed, so a single control volume contains both heavy and light fluids intimately mixed and they get separated due to buoyancy - CFX cannot model this.
November 25, 2020, 04:26 |
#9 |
Rep Power: 6 |
thanks to both of you.
@ghorrocks: I think I missunderstood you. If I use the multicomponent model, the fluids are intimately mixed. CFX just calculates one velocity field because I setup only one fluid (the mixture) in the domain. So the multicomponent model, in terms of mixing, is just doing diffusion? This means to me that the differences of the densities and the buoyancy model just supporting diffusion (micro scale) and causing no convection (bigger scale). Am I right? In that case I have to conisder to choose multiphase. Thanks again! Last edited by IrieConqueror; November 25, 2020 at 05:56. |
November 25, 2020, 04:57 |
#10 | |
Rep Power: 143 |
A multicomponent mixture does have one velocity field, but that velocity field can model convection, buoyancy, heat transfer, compressible effects etc etc, in addition to the diffusion of the multicomponent mixture. You ONLY choose a multiphase model if you have multiple phases. Your fluid is a pair of liquids - they are the same phase, so it is not a multiphase model. It is not actually that simple - multiphase models can also be used for liquids which have distinct boundaries, like oil and water. You should be aware of the definition of a multiphase flow from the CFX documentation (Modelling Guide): "Multiphase flow refers to the situation where more than one fluid is present. Each fluid may possess its own flow field, or all fluids may share a common flow field. Unlike multicomponent flow, the fluids are not mixed on a microscopic scale in multiphase flow. Rather, they are mixed on a macroscopic scale, with a discernible interface between the fluids. ANSYS CFX includes a variety of multiphase models to enable the simulation of multiple fluid streams, bubbles, droplets, solid particles, and free surface flows." In your case the mixing is at the microscopic scale, so this definition clearly states you should be using the multicomponent model.
Inlet Mixing at 1D Numerical Model | Stratified Storage | HumanistEngineer | Main CFD Forum | 26 | July 30, 2018 10:41 |
3D mixing tank using MRF/SRF | cfd_confuse | Main CFD Forum | 1 | September 13, 2016 02:43 |
Mixing Tank 3D MRF case | monty86 | FLUENT | 1 | October 9, 2015 03:43 |
Mixing tank with two phases | Jana | Fluent Multiphase | 2 | September 14, 2015 02:47 |
Mixing tank impeller | Onicon | FLUENT | 1 | March 24, 2015 02:43 |
