April 10, 2011, 14:28 |
Flow regime identification
Dmitry Volkind
Rep Power: 16 |
Greetings to everyone!
Can anyone please explain me how to identify the flow regime? For example, if I have the flow properly resolved (or precise experimental data is available), so that all characteristics of the flow are known everywhere at every timestep, how do I determine whether the flow is laminar, turbulent or transitional? Thanks in advance, Dmitry |
April 10, 2011, 22:23 |
Rep Power: 143 |
If turbulent it will have a turbulence spectrum covering a wide range of time and spacial scales. A laminar flow will have only a limited range of time and space scales.
April 11, 2011, 09:06 |
Dmitry Volkind
Rep Power: 16 |
Thank You, Glenn! Could you please explain what is considered wide or limited range?
April 11, 2011, 18:35 |
Rep Power: 143 |
Go to your library and look at any textbook on turbulence modelling or turbulence theory. This is all basic turbulence modelling theory and should be explained in detail by any decent textbook. The text I use is "Turbulence modelling for CFD" by Wilcox, but there are many others.
April 12, 2011, 03:09 |
Dmitry Volkind
Rep Power: 16 |
Thanks again! I'll try to find some books. It has become really difficult, because foreign technical books are no longer published since USSR(
April 12, 2011, 07:32 |
Rep Power: 143 |
Then you should be able to find a USSR turbulence textbook. There are lots of textbooks on the topic so I bet you can find a Russian one.
identify, laminar, turbulent |
benchmark: flow over a circular cylinder | goodegg | Main CFD Forum | 12 | January 22, 2013 11:47 |
reversed flow at velocity inlet / mass flow inlet | ib | FLUENT | 1 | March 26, 2007 13:11 |
How to change from mass flow to volume flow rate | stanley | FLUENT | 1 | February 2, 2007 06:44 |
transform navier-stokes eq. to euler-eq. | pxyz | Main CFD Forum | 37 | July 7, 2006 08:42 |
Boundary Layer Flow Paradox | Wen Long | Main CFD Forum | 3 | September 24, 2002 08:47 |
