Extract csv.file
Old   December 13, 2020, 16:17
Default Extract csv.file
Sara
Knowledge is on a distinguished road
Hi
I want to make some graphs of the data I have obtained in CFX. I want to make a graph that shows the temperature change over time for different simulations. Therefor I want to extract the data time and temperature, how is it possible?
Thank you!
Knowledge is offline   Reply With Quote
Old   December 13, 2020, 17:00
Yes. I assume this is a transient simulation. The best way is to define a monitor point with the CEL expression you wish to calculate. Then the solver will output the value for each time step as the simulation progresses. You can get the data from Solver Manager or a command line tool.
If you have already done the simulation you can only get the values of your expression for time steps you have saved a results file for. You can use the function calculator in CFD-Post (or any of several other tools) to calculate it over all the time steps you have results files for.
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
Old   December 14, 2020, 08:09
Sara
Now I am inside the function calculator why does it assume that I want to calculate for pressure?
I can choose Ave, minVal, maxVal and want it to calculate the min, max and average temperature of the fluid not the pressure.
Old   December 14, 2020, 16:43
...... then change it from pressure to temperature. Isn't that obvious?
Old   December 15, 2020, 04:15
Sara
It is not possible I can show you the picture
Old   December 15, 2020, 06:03
There are extra controls which are not visible on your screen. The scroll bar on the right side will let you see the extra controls.
Your screen must be very low pixel resolution if it has had to be shrunk that much. You should try to run at higher screen resolution and things will be much easier. Have a look at your display settings.
Parts Operations - Extract Volume cwl STAR-CCM+ 0 November 26, 2020 05:56
Part Operation - Extract Volume cwl STAR-CCM+ 2 July 23, 2020 22:30
How to extract a defined alpha along a line for dambreak case shademani OpenFOAM 0 March 4, 2019 11:37
Big help for a little girl engineer - Extract and Supply air Dani86 Main CFD Forum 9 April 30, 2018 18:38
extract information from sample during simulation for use duongquaphim OpenFOAM Programming & Development 0 January 10, 2011 13:51
