October 27, 2010, 17:00 |
#11 |
Joshua Counsil
Rep Power: 17 |
Michael's suggestion is correct: poor initial conditions are probably causing this. Alternatively, non-physical boundary conditions could also be the problem. You don't appear to be using any openings (inlets, outlets) so the first option is more likely the problem.
Have you tried solving the simulation with simpler numerical methods? For example, try using a lower-order advection scheme, lower-order turbulence model, lower-order turbulence numerics, etc. If this converges, gradually increase the order of accuracy. |
Fatal overflow in linear solver error. Why? | zaidun | CFX | 7 | August 11, 2016 05:59 |
ERROR #004100018; Fatal overflow in linear solver | Attila | CFX | 1 | April 13, 2012 22:22 |
Using a user-defined solver in OF | ozzythewise | OpenFOAM Running, Solving & CFD | 3 | February 8, 2011 15:28 |
Overflow in linear solver | Zaktatir | CFX | 0 | January 11, 2010 04:02 |
desperate Fatal overflow in linear solver - transient | kingjewel1 | CFX | 9 | January 5, 2010 13:53 |
