November 4, 2006, 02:12 |
Is it multiphase problem?
I'm trying to solve a conjugate heat transfer (CHT) problem in CFX-10. The geometric setup is as follows:
There is a hollow iron sphere in the air. The temperature of iron sphere is 100 Celsius and the sphere is filled with an insulating gas, SF6. Here, I'd like to simulate the heat transfer flow characteristics in all three parts: air, iron, and SF6. In CFX, I cannot setup two different gas domains: air and SF6. Is it multiphase problem? I highly appreciate if you can provide me any hints and comments for solving this problem. Thanks, Se-Hee |
November 4, 2006, 04:25 |
Re: Is it multiphase problem?
You can setup two domain with different physics. Set variable "CFX5_NO_CONSTANT_PHYSICS" to a nonzero value. For more information please search this forum.
hdj |
Complex multiphase melting problem | leff | CFX | 12 | March 18, 2014 16:46 |
Mass conservation in multiphase problem | cna | FLUENT | 6 | April 4, 2010 10:16 |
UDF problem in multiphase model | Amir Khodabandeh | FLUENT | 1 | March 13, 2009 08:43 |
Problem of B.C. in Eulerian multiphase model | Derek Jing | FLUENT | 0 | May 12, 2002 11:52 |
CF4 - need advice on setting up multiphase problem | Brett Towler | CFX | 2 | August 18, 2000 16:38 |
