CFX-Turbomachinery-Use Conjugate Heat Transfer or Not? |
January 2, 2021, 08:28 |
Rep Power: 5 |
Hello, Happy New Year!
I am involved in a project regarding the simulation of an axial turbine. The final purpose of the project is to specify temperature and stress distribution along blades. The first step I have done so far is a steady-state analysis using CFX. I have imported mesh for fluid domain that I created in TurboGrid. I succeeded a good convergence plot and then imported the result for Thermal Analysis and Structural Analysis on Ansys-Mechanical. In literature I have found that Conjugate Heat Transfer (CHT) promises more accurate results. What is the difference between direct importing of CFXs' results to Ansys Mechanical and CHT ? Is it worth to carry out CHT or the results will slightly differ from what i have done? If CHT is worth to perform it, I know that i have to import mesh for solid domains of blades of interest and create the interfaces between solid-blade and fluid-flow. The problems i need to resolve are: 1. It turns out with an error because of similar domain that was used twice in the analysis. It was actually the blade surface and I deleted it from the flow domain and let only the inerface to take place in my model. Is that right ? 2. I defined in turbogrid tip clearance. Do i have to create a new blade in Design Modeler and cut it to the specified tip clearance or is there an automatic way to perform that ? P.S. All I need are insights about the previous steps of that tutorial: https://www.youtube.com/watch?v=R9G8_tlz74c&t=31s |
January 5, 2021, 17:45 |
Rep Power: 143 |
It is all a matter of what causes significant effects on something else.
The temperature of the fluid affects the blade obviously. But does the temperature of the blade affect the fluid temperature significantly? Or the flow field? The answer to this question determines whether you can do one-way coupling (transferring the results from CFX to ANSYS Mechanical) or require two-way coupling (CHT).
January 6, 2021, 19:27 |
Rep Power: 5 |
Hello! Thank you for your reply!
In a sense of engineering understanding it seems that the turbine temperature would not affect much the flow so I think that one way fsi is proper for my case as i am concerning about temperature on rotor blades (without cooling flow). But, in my literature survey i found related publications that use CHT even if it is about the rotor blades. Could you please give me your insights ? |
January 6, 2021, 19:43 |
Rep Power: 143 |
Insights on what? If you want general information then try a textbook or the literature. If you have a specific question we will try to answer it.
January 6, 2021, 19:57 |
Rep Power: 5 |
Thank you for your prompt response! If you have any suggestions for related textbooks or anything that will help my study please refer to them.
I am not searching the easy way, I really want to get all the appropriate knowledge in that field. By the way i am learning on my own, so if you have something related in mind it will save me a lot of time searching the net! |
axial turbine, cfx, conjugate heat transfer, turbomachinery |
No conjugate heat transfer between solid (cast iron) and fluid (water) part | Rajaero | FLUENT | 5 | June 25, 2023 03:07 |
Current state of conjugate heat transfer in OpenFOAM | Dreoasteh | OpenFOAM | 2 | April 4, 2023 13:47 |
CFX does not solve heat transfer at fluid-solid interfaces | Ivan Corgozinho | CFX | 2 | April 7, 2015 00:08 |
Conjugate heat transfer FLUENT vs CFX | pstreufert | ANSYS | 0 | October 5, 2011 15:47 |
CFX Heat Transfer | RJamison | CFX | 0 | July 24, 2008 12:11 |
