why CFX help can't work?
Old   December 15, 2006, 22:45
Default why CFX help can't work?
prayskyer
when i turn the help on, it can't work!!!
the box's message like this:
error reture from help viewer,intialiseJAReader:Envionment variable CFX5JAVE not set.
why this happen,could anyone help me~~~
Old   December 16, 2006, 08:33
Default Re: why CFX help can't work?
Omer
Try installing the latest JAVA Virtual Machine, seems like your system doesn't have one.
Old   December 16, 2006, 10:44
Robin
You can also find PDF's of the documentation in the CFX installation under <CFX ROOT>/help/pdf. As Omar said, however, the problem is probably that you don't have the JAVA machine installed or need an update.
-Robin
Old   December 16, 2006, 20:32
prayskyer
seems i can download that machine from the internt,
thanks a lot
Old   December 16, 2006, 20:50
prayskyer
can't work, is there other problems could happen?
Old   December 17, 2006, 16:15
Omer
Should have worked. Do you have the latest one? Now that you have JVM, and things aren't working anyway. Try to install CFX again! ( Before doing so, check from your task manager, if JAVA.exe is running or not!)
OpenFOAM vs. Fluent & CFX marco FLUENT 16 November 17, 2020 04:53
CFX vs. Fluent George FLUENT 43 May 15, 2012 23:42
OpenFOAM vs. Fluent & CFX marco Main CFD Forum 81 March 31, 2009 14:22
Importing solutions in CFX. Alphonso CFX 1 August 1, 2008 14:01
CFX 4.4 installation problem Pandu Sattvika CFX 1 December 1, 2001 04:07
