Remote connection to n1173 exited with return code 127.
Old   January 20, 2021, 04:33
Default Remote connection to n1173 exited with return code 127.
Charalampos
AlekosStuttgart is on a distinguished road
2020 R2
Point Releases and Patches installed:
ANSYS, Inc. Products 2020 R2
CFX (includes CFD-Post) 2020 R2
Icepak (includes CFD-Post) 2020 R2
Remote Solve Manager Standalone Services 2020 R2
ANSYS, Inc. License Manager 2020 R2
Setting up CFX Solver run ...
Hello everyone,
I am new in CFX trying to run simulations in a cluster in hpc. To do so, I had to install Ansys-CFX and then to sumbit a slurm job. When I want to use more than one node, I cannot connect to more than one node. Below you can find what the out. file says.
I use "Intel MPI Local Parallel". What could the problem be? (Installation?)
I would appreciate any feedback.
Many thanks,
Charalampos
| An error has occurred in cfx5solve: |
| Remote connection to n1173 exited with return code 127. It |
| gave the following output: |
| ./cfx/ssh: line 55: exe- |
| c: pbsdsh: not found |
| Check that you have typed the hostname correctly, and that you |
| have an account "st_ac137003" on the specified host with access |
| permission from this host. You can use the following command to |
| check the connection to a UNIX machine: |
| ssh n1173 uname |
| or the following command if it is a Windows machine: |
| /cfx/ssh n1173 cmd /- |
| c echo working |
| The architecture string for host n1173 could not be determined. |
AlekosStuttgart is offline   Reply With Quote
Old   January 20, 2021, 11:25
Kira
aero_head is on a distinguished road
This thread may be a good thread to look up troubleshooting ideas:
Running Parallel in Batch mode
As ghorrocks states: you have not installed distributed parallel for CFX properly. CFX has a separate distributed parallel setup procedure and you should see the installation guide for details.
aero_head is offline   Reply With Quote
Old   January 26, 2021, 08:48
Charalampos
Hello aero_head,
many thanks for your message. Previous threads, indeed, helped me to understand many things.
I still have, though, some questions. I use ANSYS CFX 2020R2 and using MPI there is option of OpenMPI or Intel. In previous versions, there is always IBM options. Does someone know the differences between Intel, OpenMPI, Intel, IBM?
Many thanks
Charalampos
Old   January 26, 2021, 10:15
Kira
Hello Charalampos,
I have found a word press blog that provides a nice summary of the different MPI providers: https://intothewave.wordpress.com/20...mplementation/
Hope that helps.
Old   January 26, 2021, 10:53
Charalampos
Hello aero_head,
many thanks for your quick respone.
Best regards
Charalampos
Building OpenFOAM1.7.0 from source ata OpenFOAM Installation 46 March 6, 2022 14:21
No matching function error: Phase change source term added to interMixingFoam wavefunction OpenFOAM Programming & Development 2 February 4, 2022 08:46
CFX-Post exiting with return code 4 Andre Schlott CFX 3 February 10, 2005 07:08
Design Integration with CFD? John C. Chien Main CFD Forum 19 May 17, 2001 16:56
