CFX - wall heat flux
Like Tree3Likes
  • 1 Post By divarano
  • 1 Post By Robin
  • 1 Post By igor di varano
Old   December 1, 2006, 08:47
Default CFX - wall heat flux
divarano
I 've a question about sign convention in CFX. I made a simulation of steady state heat transfer of an insulated box, with internal T_in= 293 K, and outer of T= 213 K. I've to estimate the optimal thickness of insulating layer, so I created a boundary condition on the internal walls of heat transfer with heat source (energy). I've plotted the wall heat flux on a line across the layer, and noticed that heat flux varies with a peak in a range going from negative to positive values, whereas I expected that it decreases linearly, and in the best case it goes from 0 to negative flux equal to energy input source. Can you explain why this and what does it mean a negative heat flux? Thank you. Eng. Igor Di Varano
Светлана likes this.
Old   December 4, 2006, 12:54
Default Re: CFX - wall heat flux
Robin
Fluxes into the computational domain are positive, out are negative. A negative wall heat flux means heat is going into the wall, out of the fluid domain.
-Robin
Old   December 4, 2006, 16:14
igor di varano
Thank you very much, I've found some information on help soon after my previous e-mail. Now there 's another point. I've plotted the wall heat flux through the thickness, but I have only a few points and I've been requested to enhance the number of points in the layer. I've tried to fit the mesh, but without success, as I have always the same points(7). I 've read on the handbook that wall heat flux is sensitive in proximity of wall surfaces, and in a lesser way within the wall. Is it true or with more elements I can expect the desired result? Thanks a lot. Igor
CFX Heat Transfer RJamison CFX 0 July 24, 2008 12:11
Wall Heat Flux Boundaries conditions Abigail FLUENT 2 July 24, 2007 09:34
wall heat flux between two fluid zone!!! Asghari FLUENT 2 August 25, 2006 10:11
