Near wall distance factor
Old   December 9, 2006, 14:03
Default Near wall distance factor
Jonas Pedro Caumo
Hi everyone ? What is the value of near wall distance factor that you are using ? for sst i used 0.5 Do you calculate or estimate the y+ value in your simulations, is it really a good preocupation ? Thanks.
Old   December 9, 2006, 14:13
Default Re: Near wall distance factor
Joe
Read the help manual section on near wall meshing.
Old   December 9, 2006, 14:20
Jonas Pedro Caumo
it said just konwing things to use 0.5 in SST and 2.0 with others, but i need more about it. thanks
Old   December 11, 2006, 09:22
Omer
Y+ =0.5 is a good value, but ofcourse it also is very problem specific.The good thing about CFX automatic wall functions is, even if you are between 0.5 to 100 for SST model, it gives you good results. Because it uses low-Re number approximation or log profile approximation wherever they are needed. I hope I am not wrong when I say this.
Old   December 11, 2006, 09:42
Jonas Pedro Caumo
Thanks a lot, i´m going to study carefully this things to find something better. Your post helped me!! Because it is an specifc thing and a few people use this.
Natural convection in a closed domain STILL NEEDING help! Yr0gErG FLUENT 4 December 2, 2019 00:04
calculate distance from wall to neighbourig cell centroid rr123 Fluent UDF and Scheme Programming 39 March 14, 2017 01:41
About dimensionless wall distance L1011 Main CFD Forum 24 June 9, 2014 08:45
Find a particle's distance to a wall gruber OpenFOAM 9 February 15, 2012 06:22
Wall functions Abhijit Tilak Main CFD Forum 6 February 5, 1999 01:16
