Calculating The Torque From The Angle Of Shaft or Propeller’s Normal Axis |
October 28, 2020, 10:39 |
Rep Power: 10 |
Hello Glenn and the other members,
I Want to calculate the relative rotative efficiency of a ship’s propeller. Relative rotative efficiency equals to (open water Torque/ship shaft axis Torque) of a propeller. It is easy to calculate the Open water torque or thrust(force) from x,y and z axises. Like torque_x()@propeller or force_x()@propeller. What I did is, when I calculate the wake of the propeller with ships hull and appendages, I easily insertEd the new axis and rotated my propeller around the inserted new axis (3 degrees shaft axis). But the problem is how can I monitor or calculate the torque of a propeller from the new axis (ship’s shaft 3 degrees angular normal axis). It might be a expression or I can look from results with a method ? Best. |
October 28, 2020, 15:41 |
Rep Power: 32 |
If you can create a local coordinate frame oriented as you want, you should be able to
torque_x_MyInclinedCoord()@Boundary In fact, you check the correct syntax using the CFD-Post calculator, and toggle the "write the expression".
High torque coefficient Cm for Vertical Axis Wind Turbine (VAWT) | tony00 | FLUENT | 11 | July 23, 2018 06:13 |
calculating Normal vector in level set method | amir2920 | Main CFD Forum | 1 | July 21, 2009 07:25 |
Calculating torque | Andrew | FLUENT | 5 | September 4, 2007 11:10 |
turbine torque calculating in Fluent | Bagus Putra Muljadi | FLUENT | 0 | May 18, 2006 02:34 |
How to update polyPatchbs localPoints | liu | OpenFOAM Running, Solving & CFD | 6 | December 30, 2005 17:27 |
