moving mesh
Old   February 3, 2007, 00:40
Default moving mesh
Jeyanth
how to move a mesh (oscillating motion) in case of diffuser vanes in a centrifugal compressor. dynamic variation is required. how to create the sub routine in that case
Old   February 3, 2007, 21:31
Default Re: moving mesh
Johnny
Are you prescribing the mesh motion, or are you looking to do it through FSI?
Old   February 4, 2007, 03:25
Jeyanth
Its not FSI... Its to simulate the vane motion.. so i've to just move the mesh dynamically and the mesh motion is to be given as the inlet condition during analysis..
Old   February 5, 2007, 08:08
jon
If you can create an expression for the motion that will be the easiest and quickest. If you can then create it and use the 'specified location' or 'specifiec displacement' option for the surface boundary conditions. Jon
Old   February 5, 2007, 08:47
Jeyanth
the problem is that i have to use rotating frame for impeller blades and oscillatory motion for diffuser blades at a time. in that case how is it possible to create an expression. Can u please explain with an example? Jeyanth
Old   February 5, 2007, 09:07
jon
I have never used the rotating frame so not sure how this would work. try tech support they will be able to help you pretty quick as it is not a new problem..
Old   February 6, 2007, 22:10
Jeyanth
thank you Jon. Please tell me How to contact tech support?
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 08:54
How to let the mesh motion solver just solve a small region near a moving boundary? zhajingjing OpenFOAM Running, Solving & CFD 9 April 28, 2016 04:15
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 19:43
Waves halted by moving mesh Piotr Czajko COMSOL 1 November 24, 2007 02:00
