Importing curve from formatted data file in ICEM ? |
April 4, 2007, 05:08 |
I wonder how to write a formatted data file which would contain a curve... Got 2 points 1 0 0 and 0 0 1 and I'd like the corresponding segment to be included in ICEM using formatted data import feature. Tx in advance |
April 4, 2007, 08:26 |
Re: Importing curve from formatted data file in IC
The first line of the file should be the number of curves and the number of points per curve - space delimited - (or the order might be reversed) - then the coordinates of the points on the following lines grouped into the individual curve groups.
Installation of OpenFOAM-1.6 on Ubuntu 9.10 | marval | OpenFOAM Installation | 2 | March 17, 2010 08:33 |
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found | piprus | OpenFOAM Installation | 22 | February 25, 2010 13:43 |
[Gmsh] Compiling gmshFoam with OpenFOAM-1.5 | BlGene | OpenFOAM Meshing & Mesh Conversion | 10 | August 6, 2009 04:26 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 17:51 |
PHI file structure | Eugene | Phoenics | 9 | November 2, 2001 22:00 |
