Question on relative velocity profile (case dispersed oil/water in vertical pipe) |
October 7, 2021, 09:21 |
mariem
Rep Power: 7 |
I am currently working on the case of dispersed liquid-liquid flows in a vertical pipe . I have a question about the relative velocity profile. I made a simple case where I only consider the mean drag force and I made two simulations one for a dispersed air-liquid flow and the other for a dispersed oil-water flow. As shown in the figure below a comparison of the transverse profiles of the relative longitudinal velocity is presented: A uniform straight profile (dispersed phase : AIR) and a profile where we get an acceleration near the pipe wall (dispersed phase: OIL). Only the dispersed fluid has been changed. Can you please tell me if there is indeed a problem with this acceleration for the dispersed oil-water case? Or is it normal and in this case could you give me an explanation? Thank you in advance |
October 7, 2021, 16:49 |
Rep Power: 143 |
Please post an image of what you are modelling and your CCL or output file.
using outlet velocity profile as inlet for next set of iterations | tricha122 | FLUENT | 0 | November 22, 2020 09:40 |
[UDF] Relative coordinates in logarithmic velocity profile | cfdworker | Fluent UDF and Scheme Programming | 25 | July 13, 2017 03:44 |
velocity profile inlet boundary condition question | Lcw | FLUENT | 3 | August 3, 2012 05:53 |
Parabolic Velocity Profile In 3 D Pipe FLow | abhimanyu_wit | FLUENT | 5 | January 28, 2012 03:39 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 09:11 |
