Minimum mass and momentum RMS residual levels |
November 2, 2021, 06:58 |
Stuart
Rep Power: 25 |
I was playing in CFX 2021 R2 by simulating turbulent airflow through a smooth pipe with a very low minimum RMS residual limit of 1E-21. I noticed that the mass and momentum RMS residual equations in CFX-Solver Manager were nicely decreasing but suddenly flat-lined at 1E-15, likewise the two SST k and omega plots. I do not recall CFX flat-lining residual levels in previous versions so is this something new? Again, I'm not aiming for a discussion about assessing convergence etc. as I was just playing about in CFX, but rather is a cap new in CFX.
November 2, 2021, 07:13 |
Rep Power: 32 |
Depends on the precision selected for the solver, single or double precision.
If you are running single precision, the maximum discernible difference between two numbers is around 1.E-6, while for double precision is about 1.E-16. Requesting a residual below 1.E-16 is something not achievable for general non-linear problems. For simple problems with low mesh count, good initial guess (effectively exact solution), you may be lucky and get it.
November 2, 2021, 10:16 |
Stuart
Rep Power: 25 |
I was using double precision.
Like I said, I was simply toying about in CFX and noticed that the RMS residuals decreased to 1E-15 and then held constant. Of course my industrial simulations never get that low, it's tough getting the momentum residuals below 1E-4 in my work cases! |
November 2, 2021, 14:47 |
#4 | |
Rep Power: 32 |
- Go to Output Control - For the results file - or for intermediate Backup Results: set Output Equation Residuals, select All Run your simulation, and post-process your backup/results file as usual. Create a Point locator, and select the Maximum Variable option, and select the "equation residual" you are interested in. Apply and you will find out where your residual is located. Try to find out what is happening around that location: poor mesh, highly recirculating flow with a coarse mesh, etc Address the issue if any. Repeat for the next equation until your model can converge to a lower residual, and hopefully smoother convergence.
November 2, 2021, 16:57 |
Rep Power: 143 |
As Opaque said, 1E-15 looks like it is the machine precision. So that is as good a convergence as you are going to get on that machine, OS, version of CFX and simulation.
The actual value you get to when you hit machine precision varies between simulations. Some are more sensitive than others - in some cases it can be 1E-4 or 1E-5. It all depends on how significant resolving the tiny difference between adjacent control volumes is for that simulation. Things which affect machine precision include: * the floating point processor in the CPU (they are not exact, they approximate floating point arithmetic. So differences in the floating point processor will determine machine precision) * The OS - 64 bit versus 32 bit * The software - 32 bit versus 64 bit, but also how the software evaluates the gradients and control volume differences affects things (you should find CFX is very good in this respect versus other software) * The simulation - The reference pressure and conditions will have a big effect on this, but also a low Re flow should converge much further than, say, a natural convection simulation where the buoyancy is modelled by an ideal gas law where tiny density differences between adjacent cells drives the flow.
November 3, 2021, 06:54 |
#6 | |
Stuart
Rep Power: 25 |
Error in liquidFilmThermo | fsch1 | OpenFOAM Running, Solving & CFD | 3 | July 3, 2019 09:40 |
Inconsistencies in reading .dat file during run time in new injection model | Scram_1 | OpenFOAM | 0 | March 23, 2018 22:29 |
Phi error in implimenting Kepsilon in DPMFoam | kinbean | OpenFOAM | 3 | December 19, 2017 17:11 |
sprayEngineFoam-T gas min/max = 204.507, 764.408 | ayhan515 | OpenFOAM Running, Solving & CFD | 2 | June 6, 2014 16:59 |
sprayFoam crashes | lukasfischer | OpenFOAM Running, Solving & CFD | 3 | July 14, 2013 11:08 |
