Geometry Error in TURBOGRID
Old   February 21, 2022, 09:37
Default Geometry Error in TURBOGRID
Gokkul Raj
Gokkul is on a distinguished road
Hello everyone
Hope you all are doing well!
I am quite new to the simulation regarding the Turbomachines. Right now, I am simulating a 2-stage turbine. I have the co-ordinates for hub, shroud, blade profile. I tried to import the file to Turbogrid but I am getting an error stating that "Start and end parametric value are identical". I tried searching for solution but unfortunately couldn't solve it. It would be great if you could assist me in this issue.
Thanks in advance.
Gokkul is offline   Reply With Quote
Old   February 22, 2022, 06:27
Henrique Stel
Stel is on a distinguished road
Not the right forum for that but anyway, could you post the hub and shroud curves so we can inspect them?
Stel is offline   Reply With Quote
Old   February 22, 2022, 09:20
Gokkul Raj
Hello Stel
Thanks for the response. I was able to figure out the mistake I made. I selected the principal axis as "Z" instead of "X". Now I am able to import the geometry.
geometry import, turbomachinery
[ANSYS Meshing] CATIA Geometry Generation and Meshing danielsullivan ANSYS Meshing & Geometry 0 April 3, 2017 21:11
Fill CAD Geometry voldemort Autodesk Simulation CFD 0 July 12, 2016 01:47
Import Deformed Geometry into Fluent lgamble FLUENT 1 February 25, 2016 13:59
Problem Importing Geometry ProE to CFX fatb0y CFX 3 January 14, 2012 19:42
[ANSYS Meshing] TurboGrid export geometry after meshing la7low ANSYS Meshing & Geometry 0 January 13, 2011 19:50
