March 18, 2022, 05:38 |
RMS as output parameter
Anton
Hello.
ANSYS CFX. Does anyone know how to output RMS residual values from the solver to the output parameters? Like, for example, efficiency or pressure drop of a stage. I found how to return the value of the maximum residual, but I can`t find the root mean square (RMS residual). Maybe who knows? https://drive.google.com/file/d/1Dqu...ew?usp=sharing Last edited by redneck pony; March 18, 2022 at 07:53. |
March 18, 2022, 16:55 |
Rep Power: 143 |
Define a CEL expression something like rmsAve(u.residual)@domain, and use that expression as a monitor point and make the monitor point an output parameter.
You might need to select the option to add the residuals to the results file to get access to this.
cfx |
Parameter set output from first block as input to another | Qbz | ANSYS | 1 | May 1, 2024 05:21 |
Harmonic balance method for calculating multi-stage turbines | HIT19B902072 | SU2 | 2 | April 24, 2022 01:31 |
How can I get a variable as output parameter from A UDF for post processing in fluent | Oula | Fluent UDF and Scheme Programming | 9 | November 2, 2018 05:35 |
Pro/E to ANSYS Parameterization Guide | Trues | ANSYS | 4 | April 18, 2018 05:52 |
calculating output parameter in cfd post | markus67 | CFX | 3 | August 26, 2015 09:28 |
