[Sponsors] | |||||
I don't want to solve some equation to save time |
hang yang
Rep Power: 5 ![]() |
Now, I am currently using CFX, additional variable is used to calculate the RTD curve, I firstly calculates the steady state, then the steady state flow field results as the initial conditions of the transient simulation, hope to get the RTD curves, but transient calculation takes too long.
I have used Fluent before, and this software has a function that after obtaining steady-state results, It can no longer solve the flow equation, momentum equation, etc., which can save the time of transient calculation. I wonder if CFX has a similar function, which can not calculate some equations. |
Rep Power: 146 ![]() ![]() ![]() ![]() |
Yes. In expert parameters have a look at the solver over-rides. You can choose to turn equations off to save simulation time. It means that variable will not get updated and will stay at the values in the initial condition.
hang yang
[QUOTE=ghorrocks;825522]Yes. In expert parameters have a look at the solver over-rides. You can choose to turn equations off to save simulation time. It means that variable will not get updated and will stay at the values in the initial condition.[/Q
I don't know how to close some equations, can you tell me |
What do you mean by "close some equations"?
Do you mean turn them off? If so, then my previous post explains that. If you mean something else please explain what you mean.
hang yang
Rep Power: 34 ![]() |
just be careful, turning off equations is a dangerous thing unless you are aware of ALL dependencies between the equations.
The flow equations are decoupled from the energy equation ONLY for constant properties single component material; otherwise, they are fully coupled and they cannot be turned off from one another. If your additional variable interacts with other equations, those equations cannot be turned off either. It can be done, but carefully
Gert-Jan
Rep Power: 29 ![]() |
In expert parameters set:
solve fluids = f solve turbulence = f f is false, t is true. |
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| High Courant Number @ icoFoam | Artex85 | OpenFOAM Running, Solving & CFD | 11 | February 16, 2017 14:40 |
| Extrusion with OpenFoam problem No. Iterations 0 | Lord Kelvin | OpenFOAM Running, Solving & CFD | 8 | March 28, 2016 12:08 |
| Floating point exception error | lpz_michele | OpenFOAM Running, Solving & CFD | 53 | October 19, 2015 03:50 |
| Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 07:20 |
| mixerVesselAMI2D's mass is not balancing | sharonyue | OpenFOAM Running, Solving & CFD | 6 | June 10, 2013 10:34 |
