July 9, 2007, 09:13 |
steady state solution
Does steady state solution depends on your initial guess? cfxdude |
July 9, 2007, 09:35 |
Re: steady state solution
A complete converged solution (i.e. constant values in monitoring points, imbalances=0, RMS residuals < 1e-6) should not depend on initial guess.
Gert-Jan |
July 9, 2007, 09:57 |
What you are saying is that If 1e-5 < RMS residuals (pressure and velocities) <1e-4 and 1e-6 < RMS residual (k-e turb) < 1e-3 is not a steady state solution, or the solution depends on the initial guess? In my case the velocity of the monitored point is fluctuating between 0.25 - 0.35 m/s (11000 iteration), but the volume average velocity is constant. which one is the correct steady state indication. Thanks. cfxdude |
July 9, 2007, 10:31 |
When your monitoring values are fluctuating, you won't have a steady state situation. Looks like your problem is time dependent.
Gert-Jan |
July 9, 2007, 10:38 |
So constant volume average velocity is not the steady state indication.
Is there any book or paper about these, I am looking for some thing written. Thanks for your time. A.A. |
July 9, 2007, 18:20 |
For a small number of situations the steady state solution does depend on the initial guess. I have seen some flows were the Coanda effect caused a jet to stick to one wall or the other depending, then settle down to a steady state solution. Which wall the jet stuck to depended on the initial guess. In general, however, a fully converged solution is independent of initial guess. Glenn Horrocks |
July 9, 2007, 18:28 |
If the velocity of the monitored point is fluctuating between 0.25 - 0.35 m/s after 11000 iteration, try to increase gradually the timescale. In this way you should obtain a non fluctuating velocity value.
Probably now you are reading some fluctuations of your domain; increasing the timescale works as a filter for this numerical fluctuations. Bye Alberto |
July 10, 2007, 05:43 |
Numerical fluctuations? You may damp out physical fluctuations by numerics. If you increase the time step you may stabilize the solution but you will not get a fully converged (grid independant and time step independant) solution.
I agree with Gert-Jan and Glenn |
Steady State Vs Transient answers | Kushagra | CFX | 25 | July 23, 2017 03:20 |
Solver for transonic flow? | Martin Hegedus | OpenFOAM Running, Solving & CFD | 22 | December 16, 2015 04:59 |
Steady State 2 phase problem | fivos | FLUENT | 0 | April 27, 2009 16:34 |
regarding steady state discrete phase calculations | hajszan_gyula | FLUENT | 1 | February 28, 2006 01:32 |
