October 24, 2007, 11:57 |
process vessel spray ball modelling
I was wondering if anybody has experience in the area of modelling a spray ball which is used to wash the internals of a process vessel. I have come across very little info on the subject area. We hope to model (in 2-D) the vessel and sprayball(s) with a view to varying pressures/flowrates/spray ball configurations etc to optimise the CIP process. Pressures & velocities were the inputs required in Flotran - are similar inputs required for ANSYS CFX and if so how can we infer adequate vessel cleaning from pressures/velocities?
I would appreciate any assistance with the above. Regards, Dan |
November 5, 2007, 17:15 |
Re: process vessel spray ball modelling
Setup in CFX will be similar to Flotran. How do you infer vessel cleaning from the jet properties? Good question, that is for you to research I think. Should be plenty of studies of that sort of thing around. Glenn Horrocks |
November 6, 2007, 10:10 |
Many thanks for your response Glenn. Regards, Dan
May 16, 2022, 23:05 |
run xiang
Hi bro, did you make progress in this case 15 years ago? This is also what I have encountered now.
May 17, 2022, 01:28 |
Rep Power: 143 |
I am still here
I have no idea what Dan did, he never posted again. But if you post your specific question we can try to help you - but as a new thread, as your question will be a new question.
Reference on atomization and spray modelling | alberto | OpenFOAM Running, Solving & CFD | 1 | September 14, 2012 13:14 |
CFD spray modelling | Kumar | FLUENT | 1 | September 14, 2012 12:56 |
HELP! post processing for spray modelling | hamish888 | FLUENT | 1 | August 2, 2012 10:21 |
spray dring process | Neser | CFX | 1 | January 19, 2004 09:47 |
Temperature in vessel during throttling process | Astrid | Main CFD Forum | 2 | January 31, 2001 02:34 |
