July 8, 2022, 09:33 |
getting results in cfd post
sasha
Rep Power: 3 |
Hi everybody!
I simulated an airborne wind turbine(consisting of rotor and stator) in Ansys and solved it by cfx, now I want to evaluate the result but don't know how to get a pressure coefficient plot like the paper's result(I attached the results of the paper). I tried writing this expression in cfd post according to the formula in the reference paper but it was not correct!(attached the formula) (cp = (Pressure-Reference Pressure )/(0.5*areaAve(density)@(the plane that I want to see the contur on)*((Velocity-blade velocity)^2+ (Radius * abs(omega) / 1 [rad])^2)) ) also, I tried to change it but nothing worked and sometimes I got this error: there is no data in cp! also I don't know which function and location suite for my goal I read cfd post tutorial and found nothing! this is my first project in Ansys! It would be great if you could help me or send me a relevant context to learn about the topic! Last edited by sasha-; July 9, 2022 at 05:01. |
July 8, 2022, 18:20 |
Rep Power: 143 |
The images are not attached. This FAQ might be helpful: https://www.cfd-online.com/Wiki/Ansy...n_the_forum.3F
July 9, 2022, 05:03 |
sasha
Rep Power: 3 |
thank you, I edited the post!
July 9, 2022, 06:56 |
Rep Power: 143 |
The CFX reference pressure is not (well, at least it should not be) p_inf. I presume p_inf in your equation is the far field pressure. Assuming you have the far field set to zero pressure then p_inf should be zero.
The second part of your question seems to say that you cannot generate this variable anyway. In CFD-Post you will need to define it as a new variable (I think that is the third tab), and when correctly defined it will become a variable available like velocity and pressure and all the others.
July 14, 2022, 13:29 |
sasha
Rep Power: 3 |
hi, thanks for your reply! do you know how can I generate the variable to get a plot like "fig 10" which I uploaded before? to be clear, I don't know how to write the proper expression! I searched and found out people use functions like "areaAve,..." it doesn't seems rational to me as I need to get the result along a line from inlet to outlet and areaAve seems to estimate parameters on a plane! I'm a little bit confused, can you help me?
July 17, 2022, 21:57 |
Rep Power: 143 |
I would not recommend using CFD-Post to draw graphs like that. I would export the data to python, matlab or whatever you like and do it there.
cfd - post, cfx |
Plotting transient results in cfd post or fluent | suyesh | Visualization & Post-Processing | 1 | May 13, 2016 09:54 |
CFD Post. Multiple results comparison | zombiaska | Visualization & Post-Processing | 1 | December 23, 2014 16:06 |
Import external CFD results into Autodesk CFD for visualisation | julien.decharentenay | Autodesk Simulation CFD | 0 | May 31, 2014 20:16 |
Cfd post results | rameshcfd | FLUENT | 0 | May 8, 2014 09:59 |
Question Regarding CFD Post results | sojourner | FLUENT | 0 | February 4, 2013 10:46 |
