Baffle in the cubical domain in design modeler
Old   October 9, 2007, 15:07
Default Baffle in the cubical domain in design modeler
eslam
Hi every body
I like to setup 3 baffles in a cubical domain. I like these baffles hasn't any thickness such as surface; 3 surface in the cube. How can I do it in the ansys design modeler?
Thanks eslam
Old   October 9, 2007, 18:26
Default Re: Baffle in the cubical domain in design modeler
This is called a "thin surface" and I think the gas lift reactor tutorial in CFX uses one.
Old   October 10, 2007, 03:39
Anantha
If you extrude the curve (open ended), you will get surface bodies, which can be used as baffles. If you are using closed curves, as Mr Horrocks suggested you can choose Thin Surface Option with Inward and outward thickness as zero. This will give you a surface of the closed curve.
Regards Anantha
Old   October 13, 2007, 12:16
eslam
Hi thanks for your pay attention I extrude the open end line and I produce a surface but i cant send it to CFX-Mesh. in CFX-Mesh i cant see the surface. I dont need thin surface that told dear Glenn Horrocks. I want one surface inside a cube!!
Old   October 14, 2007, 06:51
CFX Mesh does not use surface bodies, only solid bodies. You need to use the extrusion to slice the solid body such that you have your internal surface.
In DesignModeller you will need to use the slice function.
Old   October 15, 2007, 10:28
eslam
Hi Dear Glenn
It needs thickness? I can't setup it. Can you set up simple structure for me? I don't like thickness, if I have it, my mesh quality reduces and also my CPU time is very big. My E-mail: Kashi_58@yahoo.com
Thanks Eslam Kashi
Old   March 16, 2018, 08:12
Default Solution
Plausibilität is on a distinguished road
How I solved
Just put the Surface and the 3d Body in one Part in the Design Modeler and Import the Multibody-Part into the mesh module.
You should see your Body with the inside Surface as a part of the Body.
Plausibilität is offline   Reply With Quote
[Other] Connecting 3D bodies in Ansys Design Modeler chipper ANSYS Meshing & Geometry 4 January 25, 2018 09:45
Importing Points in Design Modeler danh ANSYS Meshing & Geometry 5 March 30, 2015 10:45
Design Modeler - need to insert baffle into flowfield pstreufert ANSYS Meshing & Geometry 3 August 31, 2011 18:05
Design Modeler not working tan v ANSYS 0 July 7, 2011 02:43
Info: Short Course On Thermal Design of Electronic Equipment Arnold Free Main CFD Forum 0 August 10, 1999 10:18
