January 25, 2020, 12:33 |
Making enclosure doubles number of faces
Ashley
I am trying to do a fluid flow analysis around a car. Whenever I make an enclosure on Design Modeler around my car, the number of faces double. This ends up exceeding the faces limit for the academic license. Do you know why it doubles the number of faces and if I can stop this from happening? By the way, I have tried making the enclosure on SolidWorks and using the subtract tool. However it was difficult editing the mesh becauses its just one big rectangular block and it doesn't let me select features on the car. I apologise if my questions are very naive. I have tried searching extensively for answers. Regards, Ashley |
January 27, 2020, 14:13 |
Erik
Rep Power: 23 |
After making enclosure, do you delete the original car geometry?
You should, as it is not needed anymore. |
enclosure, faces, import |
Foam::error::PrintStack | almir | OpenFOAM Running, Solving & CFD | 91 | December 21, 2022 04:50 |
parallel run OpenFoam | Srinath Reddy | OpenFOAM Running, Solving & CFD | 13 | February 27, 2019 09:15 |
[snappyHexMesh] SHM Layer Addition Phase | dickcruz | OpenFOAM Meshing & Mesh Conversion | 4 | November 1, 2018 07:05 |
GenerateVolumeMesh Error - Surface Wrapper Self Interacting (?) | AndreP | STAR-CCM+ | 10 | August 2, 2018 07:48 |
[snappyHexMesh] sHM layer process keeps getting killed | MBttR | OpenFOAM Meshing & Mesh Conversion | 4 | August 15, 2016 03:21 |
