changing pressure at outlet boundary conditions for nasa stage 37 |
March 12, 2023, 12:26 |
Ahmed Ali Mahmoud
I want an advice to know how I can chang the average static pressure at outlet boundary to obtain mass flow outlet for nasa stage 37 axial compressor where I was changing it random by steps like ( 100kpa and then 110kpa and then....) .but I think this isn't the right way.to do, so is there another way?
March 12, 2023, 17:08 |
Rep Power: 143 |
What are you trying to do?
If you are trying to do a map of compressor performance over a range of pressures, and the simulations are steady state runs then this is MUCH better done using the parametric modelling capability in ANSYS workbench, or the performance map capability in CFX.
Fail to converge when solving with a fabricated solution | zizhou | FLUENT | 0 | March 22, 2021 06:33 |
Problem with SIMPLEC-like finite volume channel flow boundary conditions | ghobold | Main CFD Forum | 3 | June 15, 2015 11:14 |
Waterwheel shaped turbine inside a pipe simulation problem | mshahed91 | CFX | 3 | January 10, 2015 11:19 |
[PyFoam] Problems with the new PyFoam release | zfaraday | OpenFOAM Community Contributions | 13 | December 9, 2014 18:58 |
Radiation interface | hinca | CFX | 15 | January 26, 2014 17:11 |
