Thermal power generated greater than shaft power available in CFX |
March 24, 2023, 03:30 |
KristianRanta
Rep Power: 9 |
I am trying to design an impeller that is required to do a certain amount of work on the fluid, and pass a required amount of mass flow.
March 24, 2023, 05:42 |
Rep Power: 143 |
Have you looked at all the normal sources of inaccuracy? https://www.cfd-online.com/Wiki/Ansy..._inaccurate.3F
March 24, 2023, 06:01 |
KristianRanta
Rep Power: 9 |
Not extensively, but around the region that I would assume is the source of the error.
March 24, 2023, 06:04 |
Rep Power: 143 |
If you have not checked your simulation for accuracy then your model could be massively inaccurate. There is no point in trying to understand the details of a simulation which is massively inaccurate.
March 24, 2023, 15:30 |
Rep Power: 32 |
When the results are not as expected, there are a few sources of errors:
1 - User pre-processing error -> Incorrect setup 2 - Discretization errors --> assume the solution is converged; otherwise, meaningless 3 - User post-processing error --> Incorrect evaluation of results 4 - User expectations from the model --> is it the correct model for the expectations? 5 - Always the possibility of software error. Where do we start? 1->5 or 5->1 ?
Thermal Stress - Modelling of an interactive coupled Simulation | macRC | Structural Mechanics | 0 | January 10, 2019 05:14 |
ATTENTION! Reliability problems in CFX 5.7 | Joseph | CFX | 14 | April 20, 2010 15:45 |
Thermal Stress by CFX | Riken | CFX | 5 | August 12, 2008 19:26 |
Determine Thermal streeses by CFX module | Riken | CFX | 3 | August 3, 2008 20:58 |
about one seventh power law in CFX | Eric | CFX | 3 | January 10, 2007 07:16 |
