Source Point injection
Old   January 4, 2008, 09:27
Default Source Point injection
Sebastian
Hello guys,
i am trying to simulate dye inserting to a mixing vessel. The aim ist to inject a certain amount of dy from a source point directly to the flow ( I m using the additional variable approach). But at the moment i m having two problems: (I should mention that i m using a rotating domain and dont have any baffles or other stuff creating turbulence....just a typical mixing experiment)
1. How can I give a direction to my dye when im inserting threw a source point? is it possible to use the continuity equation? Or is it only working for a multicomponent flow.?
2. How can i avoid that the source point ist rotating? Ist it possible to use sth like the frozen rotor for one domain ?
I would realy appreciate some help
Sebastian
block-structured mesh for t-junction Robert@cfd ANSYS Meshing & Geometry 20 November 11, 2011 04:59
surface injection or point injection? sukura_1984 FLUENT 0 September 2, 2009 09:26
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 01:24
[Gmsh] Gmsh and samplesurface touf OpenFOAM Meshing & Mesh Conversion 2 December 10, 2007 02:27
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
