July 9, 2023, 15:35 |
Sliding Mesh
fardin
Rep Power: 7 |
Hello everybody, I have two domains as shown in pic. The Square one is constant domain (not moving) but the inner square is rorating and there should be a connection between these two domains.
Link Can any body help me out? Last edited by fardin.sh; July 10, 2023 at 12:47. |
July 9, 2023, 18:45 |
Rep Power: 143 |
There is no image on your post. See this FAQ on how to post images: https://www.cfd-online.com/Wiki/Ansy...n_the_forum.3F
But I think I know the answer to your question anyway. To connect two mesh regions which slide (translate) relative to each other you should use a GGI, set to transient rotor stator. That will resolve the interface correctly from fully shut, partial open to fully open.
July 10, 2023, 12:48 |
#3 | |
fardin
Rep Power: 7 |
Fixed. Please look again. |
July 10, 2023, 19:28 |
Rep Power: 143 |
Does the inner block do a circular motion, keeping its outer edge as an interface to the outer block?
If so then this is easily done using a rotating frame of reference for the inner block, and joined to the outer block with a GGI set to transient rotor-stator. The CFX tutorials on turbomachinery will show you how to set these simulations up.
cfx, sliding mesh method |
3D CFD Sliding Mesh Problem, nodes on the interface side not moving. | vaibhavvsr | FLUENT | 0 | March 1, 2023 06:48 |
Getting divergence in dynamic mesh but not sliding mesh | niamhiefitz | FLUENT | 0 | April 20, 2021 06:08 |
Dynamic Mesh and Sliding Mesh Simultaneously | reynold92 | FLUENT | 2 | May 9, 2015 15:26 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
3D Hybrid Mesh Errors | DarrenC | ANSYS Meshing & Geometry | 11 | August 5, 2013 06:42 |
