January 2, 2024, 03:17 |
Unsteady flow calculation
Wang Zhenfei
Is it normal for the parameter fluctuation period obtained from unsteady calculations to be greater than the rotation period? What is the reason for it?
January 2, 2024, 03:34 |
Rep Power: 143 |
Are you doing a rotating machinery simulation? What are you modelling? What parameter are you looking at?
But talking about it in general: This could be physical: for example the flow is dominated by other factors than the rotation and that is causing the parameter fluctuation, like the pipe downstream of the rotating machinery has a resonant frequency which is larger than the rotational period with a compressible fluid. This could be numerical: (that is, a simulation error) - your simulation has not converged, is numerically inaccurate or has not achieved a repeatable periodic flow yet.
Intuition for why flow follows convex surfaces | lopp | Main CFD Forum | 47 | February 1, 2022 13:14 |
Issues on the simulation of high-speed compressible flow within turbomachinery | dowlee | OpenFOAM Running, Solving & CFD | 11 | August 6, 2021 06:40 |
how to predict unsteady flow from case definition? | Felix | Main CFD Forum | 6 | August 28, 2007 16:40 |
Unsteady simulation on the flow around Naca0012 | Peter Pan Zhang | FLUENT | 2 | June 11, 2006 19:53 |
unsteady calculation | bjcz | Main CFD Forum | 5 | May 9, 2002 18:57 |
