The computer unexpectedly shuts down during cfx steady-state solution. |
March 12, 2024, 19:58 |
Xiangjie Qin
Rep Power: 2 |
The computer unexpectedly shuts down during cfx steady-state solution. Can I resume the calculation?
March 13, 2024, 05:03 |
Rep Power: 143 |
If you have saved a backup file then yes. If not then the simulation is lost and you need to start again.
If you are running on an unreliable computer then you need to save backup files regularly so you do not loose everything.
March 13, 2024, 08:10 |
Rep Power: 32 |
There is no reason for the computer to shut down when running Ansys CFX, or any software unless is explicitly ordered to shut down (given the correct permissions)
However, if your computer has a cooling issue, and it is being used to maximum it may be overheating, and the failsafe mechanism is shutting itself down for protection.
Transient simulation -> Steady state solution | saisanthoshm88 | CFX | 13 | April 10, 2024 04:43 |
How to use steady state solution to initialize transient sim on journal file | Milimo | FLUENT | 3 | May 24, 2022 07:32 |
Karman vortex - steady state solution with RANS ? | CellZone | Main CFD Forum | 4 | September 28, 2018 03:11 |
Domain Reference Pressure and mass flow inlet boundary | AdidaKK | CFX | 75 | August 20, 2018 05:37 |
Constant velocity of the material | Sas | CFX | 15 | July 13, 2010 08:56 |
