April 14, 2008, 05:46 |
controls issue in cfx mesh
I have a problem with the controls in cfx mesh. everytime I try to create a point, a line or a triangle, i can't pick te spacing I've created, and an error text box appears, saying :"
SCRIPT ERROR Line: 11488 char: 8 error: type mimatch Code: 800a000d Source: Microsoft Jscript runtime error Script: m_gfx.getWindowManager().drawTetSize(ls, ls); " Hopefully someone has already had the same issue ! thanks in advance for your help ben paillard, phd student at l'école navale française |
March 17, 2009, 05:57 |
Have you found a solution
Maximilien
Hey,
I have the same error and I don't know how to fix it. Have you find a solution? Thanks. |
February 7, 2010, 19:31 |
Michael Jasiczek
Sorry to bring up such and old post, however i suffer the same problem, it seems to be some sort of coding error with MSJscript somewhere if i understand it correctly, but no idea on how to fix it. This issue seems to be present in any geometry i create and try to mesh. If anyone has some idea on how to fix that I'd appreciate it. I use Ansys 12.0 academic license. Regards Last edited by Michael.J; February 7, 2010 at 19:48. |
February 8, 2010, 05:14 |
error in CFX-Mesh
Maximilien
this error can be make by graphic card drivers. You can try to update yours graphic card drivers. You can try to use CFX-Mesh 12.1 (this error seem disappear in 12.1). Good luck |
February 8, 2010, 06:30 |
Rep Power: 143 |
If that does not work I would make sure your javascript is up to date and you have the latest browser updates.
February 8, 2010, 07:26 |
Michael Jasiczek
I tried different display drivers, and installed latest java and nothing seems to help I am running laptop with ati 2600 hd. If anyone has some other ideas i'll be glad to test them
February 8, 2010, 14:36 |
#7 | |
Maximilien
I tried with 12.1 and no problem. Do you try with 12.1? You can read your geometry and your project which be done in 12.0 in WB 12.1 so you don't loss your work. Try and tell us if it works. |
February 8, 2010, 14:44 |
Michael Jasiczek
I am going to try 12.1 tommorow perhaps when i get to University, and i'll ask someone from academic staff what might be solution for this. I am going as well to try some different computer setup (currently intel/amd on win xp x86) amd/nvdia and Vista system. I'll post about my results.
February 9, 2010, 04:16 |
Michael Jasiczek
Ok I am quite confused I've reinstalled system (win XP) on my laptop (intel/ati) and installed ver 11.0 and still getting the same error ((((((( I even have installed ansys 12.0 and 12.1 on my second desktop with different hardware (amd/nvidia and vista system) and I still get this error no java/driver updates help.
February 9, 2010, 08:28 |
Michael Jasiczek
I am uploading screen shot of the problem, perhaps this will be more clear. I also start to think that this might be connected with some parameters of cfx mesh, if anyone has some ideas or sugestions i'll be greatfull.
May 21, 2010, 10:35 |
#11 |
Roman
I think I have solved this problem:
just correct line: m_gfx.getWindowManager().drawTetSize(ls, ls); to this one: m_gfx.getWindowManager().drawTetSize(0, 0); in file c:\Program Files\ANSYS Inc\v120\AISOL\CFXMeshApplet\CMPages\Scripts\CMHig hlighter.js Good luck Last edited by romif; May 24, 2010 at 11:09. |
October 20, 2010, 09:36 |
#12 |
Tanks alot! It worked perfectly;-)
January 20, 2012, 03:27 |
#13 |
Alexey
romif. thank you for your information. But, I thinks that I found better solution of that problem:
in file c:\Program Files\ANSYS Inc\v120\AISOL\CFXMeshApplet\CMPages\Scripts\CMHig hlighter.js find function: function doHighlightPointSpacing( p_id, p_origin ) within the body of that function replace string: var ls = m_om.getFirstQueryElementValue( p_id, "./LengthScale", true ); on var ls = parseFloat(m_om.getFirstQueryElementValue( p_id, "./LengthScale", true )); Good luck |
Create moving mesh without simulating (CFX) | spatialtime | ANSYS | 2 | July 22, 2010 10:30 |
hex mesh using cfx mesh. | mehul | CFX | 0 | October 31, 2005 07:01 |
importing mesh from ICEM CFD into CFX 5 | Jay | CFX | 2 | November 12, 2002 13:46 |
