[Domain]Three different Domain
Old   April 26, 2008, 23:17
Default [Domain]Three different Domain
Young
Dear My Colleagues
I have tired to make a radiant floor model.
But I'm in trouble.
As you know, there are three different domain types
__________________________________
Room â€" Fluid Domain (Ideal Gas)
Slab â€" Solid Domain (concrete)
Tube â€" Fluid Domain (water)
When I make room a fluid domain with idea gas, the fluid property of the tube domain (which was assigned with water) is changed automatically as water.
How do I separate the domain between room and tube?
Thanks your attentions
Old   April 26, 2008, 23:44
Default editied : [Domain]Three different Domain
Young
Dear My Colleagues
But I'm in trouble.
When I make room a fluid domain with idea gas, the fluid property of the tube domain (which was assigned with water) is changed automatically by Idea gas as room domain.
Moreover, tube domain is automatically assigned bouyancy and radiation input as room domain.
Old   April 27, 2008, 13:49
Default Re: editied : [Domain]Three different Domain
andy2o
This caused me problems once in the past, but is very easy to fix. Look up "Constant domain physics in the CFX help". A short quote from the documentation describing what to do is below:
"By default, CFX-Pre always enforces the physics between fluid domains to be consistent. However, for some classifications of problem it is viable to define different physics in different dis-connected fluid domains. In order to de-activate the enforcement of constant domain physics, select Edit > Options > CFX-Pre > Enable Beta Features and a new action becomes available in the right-click menu on the 'Simulation' branch of the tree. The 'Constant Domain Physics' action can then be de-selected if required."
There is another method to do the same thing which doesn't use beta options. It uses an environment variable to tell CFX to allow different fluids. Search for it in the help system...
Regards, andy
Old   April 27, 2008, 14:11
Young
Hi Andy,
Thank for your help...
I can fix the problem with your comments.
I appreciate you.
Best Regards,
Young
Domain Imbalance HMR CFX 5 October 10, 2016 05:57
Domain format problem on airfoil flow simulation andrenonaka CFX 14 December 7, 2015 00:42
Vertical Axis Wind Turbine Rotating Domain Problems TWaung CFX 4 May 1, 2012 03:14
CFX domain comparison Kiat110616 CFX 4 April 3, 2011 22:43
CFX Solver Memory Error mike CFX 1 March 19, 2008 07:22
