Vorteks shedding Fluent vs. CFX
Old   May 19, 2008, 18:23
Default Vorteks shedding Fluent vs. CFX
Librarian
When doing a simulation of flow around a cylinder (same mesh, reynolds number, time step etc...) we see always different transient results between cfx and fluent. We tried fine meshes, small time steps...steady-state is not so different.
Which code is correct do you think?
Have you try to compare fluent and cfx on the same case? do you have same results give or take a few?
thanks
Old   May 19, 2008, 22:32
Default Re: Vorteks shedding Fluent vs. CFX
Rogerio Fernandes Brito
First, i recommend you to make a comparison with experimental data. I think itīs more important, after that, you can choose a software that u want to work. I made 2 comparisons with 2 experimental data and i had different deviations (with different cases).
After that, I made a comparison only with femlab (2D study) and CFX 11 (3D study) for conducting heat transfer (only solid domain) and i had the same results between cfx and femlab.
Mesh and Solve Times for CFX, Fluent, CD-adapco Jade M Main CFD Forum 4 August 28, 2012 02:54
Fluent and CFX Ale Main CFD Forum 7 July 30, 2008 21:14
CFX forum Vs Fluent University forum Amvy CFX 4 February 12, 2008 16:44
Fluent Vs CFX, density and pressure Omer CFX 9 June 28, 2007 04:13
Jobs in cfd - fluent or cfx? jobman Main CFD Forum 6 July 5, 2006 15:02
