flow through porous fibers
Old   May 24, 2008, 07:02
Default flow through porous fibers
ranjith
I am modelling flow of water through porous cylindrical polypropylene fibers. The fiber is enclosed in a closed cylindrical cylinder again filled with water.The fiber has an inner diameter of 220 micrometres and the thickness of the porous wall is 40 micrometre thus giving an outer diameter of 300 micrometre. I am looking at two flow rates 1 ml/min and 10 microliters/min(along the tube). The respective mean velocities and reynolds number are .44 m/s(Re 48) and .0004m/s(Re .048).
Now I am interested in the diffusion of the water through the porous wall.Should i use darcy's equation(with just the linear term) or the darcy Forchheimer equation with both the linear and nonlinear terms. Also are there any formulas for the permeability and loss coefficients for such thin fibers. please help.....
Flow through porous medium using CFX: lack of convergence Chander CFX 3 July 23, 2014 06:32
Compressible flow through porous media? JoFFe CFX 2 November 1, 2010 04:50
flow through porous fibers ranjith Main CFD Forum 1 May 24, 2008 09:05
porous media flow Siraj Siemens 4 February 24, 2006 22:24
air flow through porous pipe faiz rauf FLUENT 3 August 11, 2004 15:08
