ICEM Meshing error
Old   June 6, 2008, 00:45
Default ICEM Meshing error
CC
I used the "2D planar" blocking method to mesh my 2D rectangular pipe with a single indentation. When I turned on the "pre mesh" option, everything looked ok; there were quad elements nicely setup. When I clicked "compute mesh" and selected "hexa dominant", ICEM 11 gave the following error:
error orienting normals, perhaps there is more than one region error in output_region_boundaries Hex Dominant meshing failed
Just wondering how this could happen when everything looked ok in "pre mesh"? How would I fix this problem?
Thanks! CC
Old   June 6, 2008, 10:59
Default Re: ICEM Meshing error
myron
You simply need to convert the pre-mesh to an unstructured mesh (this can then be written to your solver). If you right-click on Pre-Mesh you should see the option 'Convert to Unstructured Mesh'.
The hexa dominant meshing is for filling a volume mesh based on an existing surface mesh.
OpenFOAM install on Ubuntu Natty 11.04 bkubicek OpenFOAM 13 May 26, 2011 05:48
error while running paraFoam! padmanathan OpenFOAM 9 October 13, 2009 05:17
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 20:30
Problems of Duns Codes! Martin J Main CFD Forum 8 August 14, 2003 23:19
error while compiling the USER Sub routine CFD user CFX 3 November 25, 2002 15:16
