Wall heat transfer coefficient -plot in post
Old   June 23, 2008, 05:31
Default Wall heat transfer coefficient -plot in post
Nav
Hi I had solved a problem in NaturalConvection ie of fully buoyanct model;there while plotting Wall heat transfer coefficient value when given For a particular heat sink region colour-range-local ..i would get a value range of about 3000Wm^2K^-1 as maximum value. but given colour-range -userspecified - (a range of about )0 to 30Wm^2K^-1 ,there was not even a mark of red (ie highest value plot is not even 30Wm^2K^-1... Could u suggest what values have to be taken as correct.
thanks
Two-sided Wall Heat Transfer BC - No Separate Solid Mesh and No Heat Transfer Coeff swahono OpenFOAM Running, Solving & CFD 10 October 15, 2018 05:43
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
Constant velocity of the material Sas CFX 15 July 13, 2010 08:56
WALL HEAT TRANSFER COEF...AGAIN Carl CFX 2 July 8, 2005 01:35
Post processing for heat transfer coefficient veebs CFX 0 August 3, 2001 04:27
