Imposing outlet values of longer duct
Old   July 21, 2008, 17:00
Default Imposing outlet values of longer duct
underGroundMan
Hi guys
Can I impose outlet values of longer duct, which I have run as steady state, on my actual duct which I want to run as unsteady state.
Regards
Old   July 21, 2008, 22:20
Default Re: Imposing outlet values of longer duct
You should be able to save it as a BC profile and use that in your transient boundary condition.
Old   July 22, 2008, 05:48
underGroundMan
Thanks Glenn.
Regards
Old   July 22, 2008, 09:28
Rogerio Fernandes Brito
On CFX-Post, create a file in exporting a file.dat with the coordinates x,y, and z plus your values of your variable! You must create a plane or a line to do this on the outlet of your computational domain!
Old   July 23, 2008, 13:49
underGroundMan
Hi Rogerio
Thank you for your answer. Can I not simply export BC profile of my results? For location I can select inlet and profile type as Inlet Velocity. Is this method correct?
Regards
Old   July 23, 2008, 14:17
Output tab => CFX-Pre: create some points (x,y,z) on outlet with velocities and after that, u will able to use them on the next simulation! Itīs easy!
Old   July 23, 2008, 16:02
underGroundMan
Can I also use BC profile?
Regards
Pressure Outlet Guage pressure Mohsin FLUENT 36 April 29, 2016 17:16
Outlet values of longer duct underGroundMan FLUENT 0 July 21, 2008 17:03
Outlet values of longer duct underGroundMan Main CFD Forum 0 July 21, 2008 17:01
flow simulation across a small fan jane luo Main CFD Forum 15 April 12, 2004 17:49
Impinging Jet. Outlet Boundary Condition Vincent Main CFD Forum 0 December 16, 2003 10:49
