Instantaneous pressure and temperature
Old   August 17, 2008, 22:51
Default Instantaneous pressure and temperature
George Thomas
Hi, I'm trying to model IC engine combustion in CFX. I'm trying to specify a variable Heat Transfer Coefficient, and for that I need to get instantaneous pressure and temperature in the model to use in the expression for evaluating HTC. Is there any means by which I can use the instantaneous pressure and temperature at any point in the model during the simulation, to use in the expression for evaluating HTC. Thank You.
George
Old   August 20, 2008, 04:47
Default Re: Instantaneous pressure and temperature
Terje
You can introduce a user expression which can be a function of any variable.
e.g
h = 10000[W/(m^2*K)] + 100[W/(m^2*K^2)]*T + 10[W/(m^2*K*Pa)]*p
where T and p are the standard names for temperature and pressure used by CFX. Then you define your define your heat transfer coefficient to be h at the wall.
- Terje
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 06:27
Properties of air versus temperature AND pressure Vincent Main CFD Forum 5 July 28, 2008 06:28
Neumann pressure BC and velocity field Antech Main CFD Forum 0 April 25, 2006 02:15
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 05:13
