Operating System - Opinions please.
Old   August 14, 2008, 16:12
Default Operating System - Opinions please.
Sam Nicholls
Hello all
I have just purchased a new pc with a quad core 64-bit processor. I am intending to use the machine with ansys. I have ansys 32-bit. I now have the decision of what operating system to use? Obviously I want to maximum the amount of ram (which can be the full 4 GB if I use Vista) but would XP Pro be better?
Any thoughts/comments will be appreciated.
Sam
Old   August 14, 2008, 22:57
Default Re: Operating System - Opinions please.
Rogerio Fernandes Brito
Windows XP 64 bits in english!
Best Regards,
"O emitente desta mensagem é responsável por seu conteúdo e endereçamento. Cabe ao destinatário cuidar quanto ao tratamento adequado. Sem a devida autorização, a divulgação, a reprodução, a distribuição ou qualquer outra ação em desconformidade com as normas internas do Sistema Brito são proibidas e passíveis de sanção disciplinar, cível e criminal."
"The sender of this message is responsible for its content and addressing. The receiver shall take proper care of it. Without due authorization, the publication, reproduction, distribution or the performance of any other action not conforming to Brito System internal policies and procedures is forbidden and liable to disciplinary, civil or criminal sanctions."
" El emisor de este mensaje es responsable por su contenido y direccionamiento. Cabe al destinatario darle el tratamiento adecuado. Sin la debida autorización, su divulgación, reproducción, distribución o cualquier otra acción no conforme a las normas internas del Sistema Brito están prohibidas y serán pasibles de sanción disciplinaria, civil y penal."
Old   August 15, 2008, 02:23
Sam Nicholls
Do you run 64-bit Ansys then?
Old   August 15, 2008, 07:21
Yes, with 8 GB of ram, ASUS P5K Premium motherboard, Intel Quad Core Q6600 processor, with 4 licenses, using ANSYS CFX-v11.0 with Service Pack 1. Quite rapid!
Be of good cheer !
Old   August 15, 2008, 16:13
brunoc
Yes, if you want to use everything your hardware has to offer, install a 64-bit OS. And, of course, get a copy of the 64-bit version of the ANSYS package. You can find it at the Customer Portal.
You should also consider using linux.
Old   August 15, 2008, 18:00
Michael Boton
I don´t think the linux is necessary. I prefer using Microsoft Windows Vista.
Best Regards.
Michael Boton
Old   August 17, 2008, 19:33
There is little performance difference between windows and Linux these days for normal applications. Choose which ever you are more comfortable with.
The 32/64 bit question is much more important. If you want to run big models and have over 2GB RAM installed then go with a 64 bit OS.
Old   August 18, 2008, 03:04
Charles
What clock speed are you running on that system, Rogerio? I've got almost exactly the same system (but set up to also boot Linux), and it is quite happy to run all day at 3.2 GHz. It's an amazingly overclock-friendly combination.
Old   August 18, 2008, 07:33
How to do it (overclock)? The ASUS P5K Premium motherboard allows to do that. I don´t know about the clock speed. I think it´s 2.4 GHz.
Old   August 18, 2008, 07:55
Charles
Very carefully, if you get it wrong it's your own problem! But yes, the motherboard allows you to adjust most of the frequencies and voltages. It doesn't seem to be a problem at all to get the CPU frequency up to around 3 GHz, and the front side bus over 1350 MHz, with standard air cooling and without adjusting the voltages. You do have to make sure that the memory frequency stays within limits, fortunately, it is independently adjustable.
Old   August 19, 2008, 14:32
  #11
Sam Nicholls
Thanks for the comments.
What should I do if I also use a lot of 32-bit software? Try and find the 64-bit alternatives? If I were to run a 32-bit operating system, would XP be quicker than Vista? I will only get 3.25GB RAM with XP whereas with Vista I would see 4GB.
Old   August 20, 2008, 02:08
  #12
Most but not all 32 bit software runs fine on WinXP x64. I have no experience with Vista x64. I don't think there is a measureable speed difference between WinXP and Vista but I have never measured it.
Operating System for Ansys 13 HPC makkks Hardware 22 August 7, 2014 06:43
64-bit operating system anupmaeca Hardware 6 August 22, 2011 14:50
CFX11 + Fortran compiler ? Mohan CFX 20 March 30, 2011 18:56
Which operating system for CFX is the best? Dr. Bian CFX 12 June 26, 2006 08:58
windows operating system scientist Main CFD Forum 8 November 19, 2004 03:30
