problems with single edge error in ICEM-CFD
Old   October 28, 2008, 10:30
Default problems with single edge error in ICEM-CFD
anna
Hi every body? i have to generate a mesh from Ansys ICEM-CFD in 2-D and i want to forward it to Fluent version 6 but the mesh check field in Ansys gives me ( single edge)error how to solve this error because it make problems when translate it to fluent. could anyone help me???????? thanks for advance
Old   October 28, 2008, 11:54
Default Re: problems with single edge error in ICEM-CFD
myron
If you are talking about a 2D (i.e. planar) surface mesh - then you would expect to have single edges. The bounding surface elements will have no neighbor on the outside. This is just fine. If you're talking about a box - but only the surface mesh - then this is a problem...
For an 'open' surface mesh - make sure you have bar/line elements all around the surface (project to bounding curves). These line elements will be placed into the specific 'parts' on which to assign boundary conditions. These missing line elements on the boundaries are more likely the cause of the trouble importing to Fluent.
Old   October 28, 2008, 22:40
anna
thank you so much dear i hope so much trouble for you i will try to make an element around the 2-d plannar body and try thanks
Old   October 29, 2008, 02:27
anna
yes my case is a 2-d plannr project ( surface mesh) with no boxes so i will try to do the elements after that define the BC for each then i will see if it will be ok of not thanks so much
[ICEM] Icem CFD on Linux mechanicaldesign ANSYS Meshing & Geometry 7 March 11, 2021 19:44
Need help icem cfd kakhtar ANSYS Meshing & Geometry 25 January 31, 2017 01:09
CFD Design...The CFD Future John C. Chien Main CFD Forum 20 November 19, 2015 23:40
Learn ANSYS ICEM CFD easy_astronaut ANSYS 2 December 15, 2013 15:34
Importing Solidworks part into ICEM CFD MetalSupremacist FLUENT 0 October 8, 2010 17:46
