I have a transient run and I'm using monitor points to watch the time histories of the mass flow rates during the run so that I don't have to write out transient result files and then wait for CFX-Post to assemble a time history after the run. Is there an easy way to export the monitor point values displayed during the solution? I tried the cfx5dfile command but I end up with a lot of extra variables that I don't care about in the file and so it has too many columns for Excel to handle.
Thanks in advance for any help you can give. Tristan |
Plot the monitor point in the Solver Manager and right click on the plot to export the data to a .csv file.
Note that you don't need to create monitor points to plot mass flow rates; these are already written to the mon file, you just need to create a monitor plot. -CycLone |
CycLone,
Thanks, that's exactly what I needed. I see what you mean about the mass flow rates already being available for all defined regions. However, I needed to look at subsets of some of my regions (multiple ports) so I had to create the monitor points in CFX-Pre using the mesh region primitives. Tristan |
TimeVaryingMappedFixedValue | irishdave | OpenFOAM Running, Solving & CFD | 32 | June 16, 2021 06:55 |
max node values exceed max element values in contour plot | jason_t | FLUENT | 0 | August 19, 2009 11:32 |
exact face values | RubenG | Main CFD Forum | 0 | June 22, 2009 11:09 |
strange node values @ solid/fluid interface - help | JB | FLUENT | 2 | November 1, 2008 12:04 |
node values or cell values? | aPpA | FLUENT | 0 | November 10, 2006 08:56 |
