spanwise-average contour in CFX-post??
Like Tree1Likes
  • 1 Post By turbinesv
Old   November 9, 2008, 23:41
Default spanwise-average contour in CFX-post??
turbinesv
hello,everyone
I am doing a backward facing-step unteady simulation using CFX. How can I get the spanwise-averaged pressure contour in CFX-Post?
Thanks inadavance.
Regards,
Lan
alonely3000 likes this.
Old   November 10, 2008, 04:04
Default Re: spanwise-average contour in CFX-post??
Adam
Hi Lan, you can simply initilise the domain in turbo mode, selecting the top and bottom walls as casing and hub respectively. You do not need to choose a blade. Then you can use the options in turbo mode. However, you may find that the region close to the step is not distributed as well as the other regions of the turbo mesh.
What do you mean by span? Same direction as the step height, or accross the domain?
You can also export the results for each timestep and post process with say Matlab or Tecplot.
Cheers
Adam
Old   November 10, 2008, 20:33
turbinesv
Thanks,Adam.
My spanwise means the direction across the flow domain. I got your method in CFX-post. And how can I get the spanwise-averaged data in tecplot?
Regards,
Lan
Transient animation performance in CFX 5.5 POST Sjoerd Romkes CFX 8 February 5, 2013 14:53
CFX Post export problem jeff_F CFX 0 August 17, 2009 21:25
Chart Generation in CFX Post Vadim Baines-Jones CFX 2 August 28, 2007 09:14
Export AreaAve data at each time step in CFX Post Kumar CFX 2 August 22, 2007 12:32
ANSYS CFX POST State file Mechstud CFX 1 June 22, 2007 14:59
