November 11, 2008, 06:34 |
how to show shock waves
I am predicting the external flow around airfoil with high mach number (>0.8), in which cases shock is supposed to occur. I am just wondering how can I identify it and how to show it in my results. thanks a lot. anne
November 11, 2008, 09:39 |
Re: how to show shock waves
Just plot the pression distribution...if your mesh is fine enough you will see the shock as a sudden change in pressure...
November 11, 2008, 12:08 |
thanks,
do you mean just pressure or total pressure. I think total pressure seems more reasonable, what's your opinion. anne |
November 11, 2008, 13:15 |
Depends on what you want...for example if you want to show the non-isentropic behaviour and then the loss of total pressure plot this one... Everything depends on what you need to show...
November 12, 2008, 04:25 |
A numerical Schlieren image is also nice. Plot contours of d(rho)/dx and use an inverse grayscale colormap (tweak the range to show the shock nicely).
November 12, 2008, 15:50 |
This is the pressure gradient which can also be output to the res file. I can't recall if it is output by default (I think it is), but if it isn't you can enable output of variable operators from the output control panel in CFX-Pre. This will make you shock waves should show up nicely.
You can also create isosurfaces of Mach Number equal to one. -CycLone |
November 13, 2008, 06:32 |
thank you all so much. I am trying your ways. anne
Fluent and supersonic flows with strong shock waves | gera | FLUENT | 13 | December 15, 2015 05:21 |
CFX converge problem caused by shock waves | littlelz | CFX | 3 | August 17, 2009 09:35 |
Will compression waves overtake a moving shock? | GRA | Main CFD Forum | 2 | October 19, 2006 00:24 |
HELP! Shock waves not heating up... | PattiMichelle | Phoenics | 0 | December 27, 2005 12:31 |
Normal shock waves | Fernando Velasco | Main CFD Forum | 1 | April 6, 2000 14:10 |
