Reg Mass flow rate
Old   January 6, 2009, 01:38
Default Reg Mass flow rate
jksanil
Hi guys i am new to CFX. SO for simple analysis of flow through pipe i had given boundary conditions like at inlet mass flow rate as 10Kg/s at outlet i set relative pressure to 0Pa and default domain to wall After solving this i am getting a negative mass flow at outlet. and even the mass flow contour drawn at inlet showing a variation of 2Kg/s to .5Kg/sec instead of given 10 Kg/s. Can any body tell me what is this indicates and what are the modifications need to be taken.
Pipe is of 25mm radius and 500mm length
Thanks in advance
Old   January 6, 2009, 03:08
Default Re: Reg Mass flow rate
Timon
Negative mass flow simply signifies that you have outflow of mass. And what do you mean with mass flow contour (mass flow is an integral quantity, so how can you plot a contour)?
Particle Injection Mass Flow Rate and Position leonozx FLUENT 3 March 9, 2018 09:58
Mass flow rate at the outlet tejasvikrishna FLUENT 2 May 25, 2013 02:42
Mass flow rate sepidecent CFX 0 August 9, 2011 00:15
Mass Flow Rate is not converging destgir448 CFX 5 December 11, 2010 05:55
mass flow rate error Masood FLUENT 0 May 22, 2005 00:32
