Mass Flow Imbalance
Old   January 30, 2009, 10:59
Default Mass Flow Imbalance
Ed Mueller
I am runing a CFX analysis on a fluid pump, and when I look at the results, everything seems to be in order.
However, when I compare massflow at inlet to massflow at outlet, the outlet massflow is exactly one-half that of the inlet (the inlet massflow is correct according to hand calcs).
When I check the massflow out of the impeller, it is the same as that at the inlet so something is happening in my fluid out domain where the massflow out of the fluid out domain is precisely half of the massflow into the fluid out domain.
Does anyone have any ideas on why this is? Does this mean my run is not converged? I found it odd that it is exactly half of my inlet mass flow (to about .00001 decimal places).
Old   January 30, 2009, 11:45
Default Re: Mass Flow Imbalance
Ed Mueller
Update:
Looking at my out file, I see that domain imbalance for fluid in is 50%. Anyone have any ideas on why this might be?
+--------------------------------------------------------------------+ | Mass-Water at 25 C-fluid_in | +--------------------------------------------------------------------+ Boundary : inlet 1.2643E+02
Domain Interface : fin_to_impeller (Side 2) -6.4413E+01
Domain Interface : fin_to_wear_ring_gap (Side 1) 1.1992E+00
----------- Domain Imbalance : 6.3213E+01
Domain Imbalance, in %: 50.0000 %
Old   January 30, 2009, 14:22
CycLone
Hi Ed,
Do you have a frame change with different pitches? What type of boundary conditions have you applied?
-CycLone
Old   January 30, 2009, 14:30
Ed Mueller
My BCs are velocity inlet and static pressure outlet. I have frozen rotor frame change, but there is no pitch. All surfaces at the domain interfaces are 1:1. I partitioned the model into 3 partitions, so maybe there was an error transferring data there?
Old   January 30, 2009, 14:34
CycLone
I would check the interfaces. CFX won't get the mass flow out by 50%, so I suspect something is set up wrong.
Old   January 31, 2009, 07:20
Nitin Dewangan
if you check, CFX solver again. there has information, how mass imbalance calculated. just see that once. . the mass will be distribted around the boundary conditions, other than inlet and outlet.
Running dieselFoam error adorean OpenFOAM Running, Solving & CFD 119 February 1, 2016 14:41
Species mass flow inlet lorenz FLUENT 3 March 15, 2012 07:26
Mass flow imbalance in transient state Ton CFX 3 June 2, 2009 01:05
Mass flow and U-Mom flow in CFX Zhihua Xie CFX 0 September 3, 2007 09:49
Target mass flow rate Saturn FLUENT 0 December 10, 2004 04:18
